Hdsuisse.fhd for Newnigma2 skin
update 10.3
14.09.2024
hdsuisse one4all
thanks hdsuisse
14.09.2024
hdsuisse one4all
thanks hdsuisse
- enigma2-skin-hdsuisse.one4all.fhd_10.3_all.deb
- (4.48 MiB) Downloaded 105 times
Re: Hdsuisse.fhd for Newnigma2 skin
Update hdsuisse Skin
FHD -> Ver. 10.5
one4all
newly added:
-AudioRestart Plugin
-AutomaticVolumeAdjustment Plugin
Fix:
-Dreambox-TWO LCD "Picon" display works again
thanks hdsuisse
FHD -> Ver. 10.5
one4all
newly added:
Fix:
thanks hdsuisse
- enigma2-skin-hdsuisse.one4all.fhd_10.5_all.deb
- (4.5 MiB) Downloaded 92 times
29.09.2024
for one4all
FHD -> Ver. 10.6
I've been working on the Merlin Info Screen a bit more, I think it turned out well.
As already mentioned, the plugin works for all of my skins and with all DreamOS images.
Update:
MerlinInfo Plugin
-More info added
SecondInfobar extra info
-AudioCodec display added
UpdatCheck Plugin
-Internal software manager skinned
-Plugin from SvenH feed
thanks hdsuisse
29.09.2024
for one4all
FHD -> Ver. 10.6
Update:
MerlinInfo Plugin
-More info added
UpdatCheck Plugin
thanks hdsuisse
- enigma2-skin-hdsuisse.one4all.fhd_10.6_all.deb
- (4.5 MiB) Downloaded 100 times
26.11.2024
for one4all
FHD -> Ver. 10.8
Neu:
-ZapHistoryBrowser für alle Skins -> Download vom Image Feed
-MerlinSports für 2k Skin -> Download vom Merlin-Feed>>>https://merlinfeed.boxpirates.to/
-ChocholousekPicons für one4all & 2k Skin -> PeterPan Image
Update:
-VirtualKeybord -> Info siehe hier>>>https://dreambox.de/board/index.php?thr ... r-dreamos/
Fix:
-ExtNumberZap -> DirectoryBrowser Fix
-Diverse kleine Fixe
thanks hdsuisse
Download
https://ddownload.com/2orllb67sl1c/enig ... .8_all.deb
26.11.2024
for one4all
FHD -> Ver. 10.8
Neu:
Update:
Fix:
thanks hdsuisse
Download
one4all -> Ver. 10.8-r1
thanks hdsuisse
enigma2-skin-hdsuisse.one4all.fhd_10.8-r1_all.deb
https://ddownload.com/eepydcd33ll8/enig ... r1_all.deb
thanks hdsuisse
Update hdsuisse Skins
FHD -> Ver. 11.0
one4all
thanks hdsuisse
enigma2-skin-hdsuisse.one4all.fhd_11.0_all.deb
https://www.satworld-forum.com/download ... hp?id=7013
FHD -> Ver. 11.0
one4all
thanks hdsuisse
FHD -> Ver. 11.2
one4all 30.12.2024
thanks hdsuisse
enigma2-skin-hdsuisse.one4all.fhd_11.2_all.deb
https://www.satworld-forum.com/download ... hp?id=7171
FHD -> Ver. 11.2
one4all 30.12.2024
thanks hdsuisse
FHD -> Ver. 11.4
one4all 08.02.2024
10 neue Kanallisten für das ChannelSelectionPlus Plugin hinzugefügt
-Update des CSP Plugin auf die neuste Version 0.1.1-r6 notwendig
-Links zum CSP Plugin hier in der Skin-Anleitung im #2 Beitrag
-Die Kanallisten sind umschaltbar mit der Vorspultaste >>
-Danke Sven H für die Anpassung des Plugin für meine Skins
-Keine Abhängigkeit zum Plugin, frei wählbar ob ihr das nutzen wollt
Update:
MediaPlayer in den "FHD" Skins
-Jetzt mit horizontalen Listen
-Lange Dateinamen werden nicht mehr abgeschnitten
Fix:
Gemeldete Fehler gefixt
Diverse Korrekturen
thanks hdsuisse
enigma2-skin-hdsuisse.one4all.fhd_11.4_all.deb
https://www.satworld-forum.com/download ... hp?id=7925
FHD -> Ver. 11.4
one4all 08.02.2024
Update:
Fix:
Diverse Korrekturen
thanks hdsuisse
- 1896 Views
- 78 Replies
- 39072 Views
- 130 Replies
- 103093 Views
Last post by VivaEuropeTV
- 2125 Views
- 528 Views
