5.0.240903
Minor improvement:
- in case of a problem receiving an HTML file instead of a 7zip file, the found HTML title from the file will be displayed
- fixed wrong resolution, in case of alternate image "image_not_found.png"
Chocholousek Picons updater
- enigma2-plugin-extensions-chocholousek-picons_5.0.240903_all.ipk
- (125.61 KiB) Downloaded 93 times
- enigma2-plugin-extensions-chocholousek-picons_5.0.240903_all.deb
- (125.61 KiB) Downloaded 115 times
Re: Chocholousek Picons updater
5.0.240904
BUG fix:
File "/usr/lib/enigma2/python/Components/ScrollLabel.py", line 58, in setText
TypeError: in method 'eLabel_setText', argument 2 of type 'std::string const &'
- this was a string conversion issue between C++ and Python, in Enigma2 - Gemini Project 4.2
- thx to Warder for the BUG report and for testing the BUG fix in Gemini
BUG fix:
- enigma2-plugin-extensions-chocholousek-picons_5.0.240904_all.ipk
- (125.76 KiB) Downloaded 94 times
- enigma2-plugin-extensions-chocholousek-picons_5.0.240904_all.deb
- (125.76 KiB) Downloaded 110 times
- 1426 Views
Last post by gregor1213
