Channellist Editor for GTMEDIA GTcombo Mars
ChanSort_2024-08-18
- ChanSort_2024-08-18.zip
- (33.93 MiB) Downloaded 877 times
Re: Channellist Editor for GTMEDIA GTcombo Mars
The channelizer new update version 4.0.3
Behavior on Channels / Transponders / Satellites / Summary:
Ctrl+LeftClick → toggles item
Shift+LeftClick → range select from anchor.
Ctrl+A → select all rows.
Ctrl+C → copy selected rows (tab-delimited; includes first column if visible).
Favorites tab unchanged.
Fav column (GUI-only) on the Channels tab (doesn’t affect parsing or export).
Fav now follows row moves (Up/Down/Move to Index) by remapping TVChs/RadioChs indices after reorders.
Right-panel “Favorite” dropdown to quickly assign a channel to one favorite group (or “None”) and refresh UI.
Move Up / Move Down / Move to Index… on all tabs preserved.
Accessibility & hotkeys preserved:
Ctrl+Alt+R = Read Selection
Ctrl+Alt+T = Toggle Theme
Download:
For the antivirus issues install first the certificate
certificate password is:
PAOK4ever!@#
Download:
https://github.com/nikkpap/The_Channelizer/blob/main/Compiled/The_Channelizer_v4.0.3.exeCode: Select all
https://github.com/nikkpap/The_Channelizer/blob/main/Compiled/nikkpap_self-cert_2025.cerCode: Select all
https://github.com/nikkpap/The_Channelizer/blob/main/Compiled/nikkpap_self-cert_2025.pfxPAOK4ever!@#
- 5364 Views
Last post by chassis43
- 567 Views
- 11 Replies
- 6035 Views
- 11191 Views
Last post by Feralkiwi
- 529 Views
Last post by lennoniloveu
