Astronomy
Astronomy
Thx Evg77734
Based on astronomical calculations Sirius0103
- Plugin displays data on the position of the planets of our system and the Moon in space, as well as displays it graphically.
- The direction to the planets according to their azimuth at this point in time in relation to the place of observation.
- The place of observation is your geographic coordinates.
- Geographic coordinates are determined automatically by the corresponding service on the Internet.
- If the height of the planet (angle of the place) is greater than zero, the planet can be observed in the sky with or without instruments, in the plugin it is reflected by red and green color of the special icon.
- The data is constantly updated, as planets move, which is noticeable on the screen during long observation.
Thanks Lululla
fix py2-py3
fix png planet and plugin
enigma2-plugin-extensions-astronomy_1.1_all.ipk
(485.32 KiB) Downloaded 31 times
enigma2-plugin-extensions-astronomy_1.1_all.deb
(444.16 KiB) Downloaded 28 times
Re: Astronomy
v.1.3
Fixes from Lululla
timer routine - fixed
missing widget (Label) on skin - fixed
correct color on skcreen Info (crash on dreambox)
Locale Language bring on init file
add locale language: Slovak, Czech, Polish and Hungarian. (thank's Warder) and IT ( Lululla)
recoded call single planet
removed code unused
add label Name to planet
enigma2-plugin-extensions-astronomy_1.3_all.ipk
(425.47 KiB) Downloaded 37 times
enigma2-plugin-extensions-astronomy_1.3_all.deb
(457.4 KiB) Downloaded 24 times
Re: Astronomy
minor code, removed code unnecessary
Astronomy-recode.zip
(576.47 KiB) Downloaded 30 times
