New Update 27.08.2024 Image v5.4.1.006 For VU+ :
https://images.openbh.net/?b=5.4%2Fvuplus
5.4.1.006
[OpentvZapper] simplify
[VideoMode] tweak last commit
Add Audio Volume step size option
Try to further streamline some code in ServiceList.py
In ServiceList remove a redudant line of code that caused glitches
[ServiceName] fix potential BSoD Only call info.getName without arguments when it is not static
[opentv_zapper] fix potential BSoD
[db] Make service list editing functions available to python
[InfobarGenerics] don't block access to channel list when second infobar is shown
Update unicable.xml Inverto Item 5458 (#4050)
[unicable.xml] add more LNB
[Added] Functions for bouquets handling
Updated skin_display.xml
Updated skin_display_picon.xml
[Updated] Added separator line only if we have python tuple with size 1
[Added] Support of separator lines in ConfigList
[scan.cpp] extend LCN for DVB-C
[TerrestrialBouquet] only show section markers in tv bouquet
[TerrestrialBouquet] improve duplicate handling
[db] expose lcndata for use in C++
[ServiceScan] don't import plugin on scan
[TerrestrialBouquet] don't force menu position
[FCC] don't force menu position
[ServiceReference] add 4097 to isRecordable
[TerrestrialBouquet] import mode from ChannelSelection
[TerrestrialBouquet] use eDVBDV.getLcnDBData
Move LCNData to db.h
[TerrestrialBouquet] update text formatting
[TerrestrialBouquet] tweaks requested by @Ev0
[TerrestrialBouquet] add default arg to callback
[TerrestrialBouquet] add plugin
In config make booleans checks with saved value non case sensitive
[ChoiceBox] avoid compatibility issues
[Added] Some compatability code for pixmap scaling
[scan.cpp] fetch T2 namespace for LCN output
[scan.cpp] fix wrong debug
[scan.cpp] add dvb-t lcn support
[ScanSetup] fix bytes conversion
[ScanSetup] fix wrong variable name
[oscam startup script] Remove utf8 paramter from script
[openbh-feeds] add terrestrialbouquet plugin
[gigablue] quad4k, ue4k and x34k update rescue loader to version #200
curl add basic-auth bearer-auth digest-auth negotiate-auth
curl update to 8.8.0
Black Hole / OpenBH Update Info
- Has thanked: 14329 times
- Been thanked: 1640 times
