Streamlinkproxy Python3 Only!
Update 6.9.0
https://github.com/streamlink/streamlink/blob/master/CHANGELOG.md
Re: Streamlinkproxy Python3 Only!
UPDATE
6.11.0
1) Latest streamlink lib from GIT - https://github.com/streamlink/streamlin ... tag/6.10.0
enigma2-plugin-extensions-streamlinkproxy_6.11.0_all.ipk
(729.23 KiB) Downloaded 700 times
UPDATE 7.0.0
1) Latest streamlink lib from GIT - https://github.com/streamlink/streamlin ... /tag/7.0.0
UPDATE 7.0.0
enigma2-plugin-extensions-streamlinkproxy_7.0.0_all.ipk
(716.59 KiB) Downloaded 368 times
UPDATE
7.1.0
1) Latest streamlink lib from GIT - https://github.com/streamlink/streamlin ... /tag/7.1.0
enigma2-plugin-extensions-streamlinkproxy_7.1.0_all.ipk
(716.62 KiB) Downloaded 821 times
UPDATE 7.1.1
1) Latest streamlink lib from GIT - https://github.com/streamlink/streamlin ... /tag/7.1.1
enigma2-plugin-extensions-streamlinkproxy_7.1.1_all.ipk
(716.71 KiB) Downloaded 664 times
UPDATE
7.1.2
1) Latest streamlink lib from GIT - https://github.com/streamlink/…/blob/ma ... ANGELOG.md
enigma2-plugin-extensions-streamlinkproxy_7.1.2_all.ipk
(717.58 KiB) Downloaded 806 times
UPDATE 7.1.3
enigma2-plugin-extensions-streamlinkproxy_7.1.3_all.ipk
(716.15 KiB) Downloaded 887 times
UPDATE
7.2.0
2) Small changes in the /usr/sbin/streamlinkproxy daemon. If you need to run the streamlinkproxy “server” on a port other than 8088, just change the value of the srvport variable to the one you want and restart the daemon
If you changed the server port number, don't forget to change the same value in the bouquets you use
enigma2-plugin-extensions-streamlinkproxy_7.2.0_all.ipk
(733.17 KiB) Downloaded 739 times
UPDATE 7.4.0
2) Small changes for outputting streamlink library logs in the console
enigma2-plugin-extensions-streamlinkproxy_7.4.0_all.ipk
(733.8 KiB) Downloaded 260 times
