Levi45 Addons
Levi45 Addons
V 10.1 r19
Added HD , FHD and UHD skin support
Codes cleaned and corrected
thanks @ lululla
Levi45 Addons
version='10.1-r22'
changelog='Fix All known issues'
thanks Lululla
install via telnet use code below:
wget -q "--no-check-certificate" https://raw.githubusercontent.…5/Addon/main/installer.sh -O - | /bin/sh
enigma2-plugin-extensions-levi45-addon_10.1-r22_all.ipk
(117.52 KiB) Downloaded 483 times
enigma2-plugin-extensions-levi45-addon_10.1-r22_all.deb
(112.28 KiB) Downloaded 166 times
Levi45 Addons
version='10.1-r23'
changelog='Fix Update and Dreambox issues'
thanks @ lululla
enigma2-plugin-extensions-levi45-addon_10.1-r23_all.ipk
(119 KiB) Downloaded 131 times
enigma2-plugin-extensions-levi45-addon_10.1-r23_all.deb
(113.63 KiB) Downloaded 115 times
Re: Levi45 Addons
version='10.1-r24'
changelog='Fix Dreambox issues'
thanks @lululla
wget -q "--no-check-certificate" https://raw.githubusercontent.com/levi- ... staller.sh -O - | /bin/sh
enigma2-plugin-extensions-levi45-addon_10.1-r24_all.ipk
(119.45 KiB) Downloaded 112 times
enigma2-plugin-extensions-levi45-addon_10.1-r24_all.deb
(113.86 KiB) Downloaded 107 times
Re: Levi45 Addons
Online update
version='10.1-r25'
changelog='Added Hide ATV Sections' (with enabling parental control )
thanks @lululla
enigma2-plugin-extensions-levi45-addon_10.1-r25_all.ipk
(119.5 KiB) Downloaded 105 times
enigma2-plugin-extensions-levi45-addon_10.1-r25_all.deb
(113.9 KiB) Downloaded 95 times
Re: Levi45 Addons
Online update
version='10.1-r26'
changelog='If you on dream box shows only .deb files, and if you on all other boxes then shows only .ipk files'
Thanks @lululla
enigma2-plugin-extensions-levi45-addon_10.1-r26_all.ipk
(119.7 KiB) Downloaded 218 times
enigma2-plugin-extensions-levi45-addon_10.1-r26_all.deb
(114.07 KiB) Downloaded 118 times
Re: Levi45 Addons
Update
version='10.1-r27'
changelog='Fixed Dreambox issue'
Thanks @lululla
enigma2-plugin-extensions-levi45-addon_10.1-r27_all.ipk
(119.75 KiB) Downloaded 423 times
enigma2-plugin-extensions-levi45-addon_10.1-r27_all.deb
(114.09 KiB) Downloaded 135 times
