ShadowFHD Skin for DreamOS
Been thanked: 2741 times
Update: v2.0-r16 >>>>>(Online Update)..
New update:28.07.2024
- neues schaltbare Mainmenü mit Namen EDM ,dies zeigt mit aktuellem EDM Plugin im Hauptmenü die EDM Bild und Info Daten..
- internes..
Thx @zombi
Re: ShadowFHD Skin for DreamOS
Update: v2.0-r23 >>>>>(Online Update)..
New update:14.09.2024
- Anpassung im EDM Suchscreen an das neue EDM Update..
- DreamXtream wieder mit geskinnt..
- neue und zusätzliche Displayscreens für die Two..
- Hauptmenüicons für DreamXtrem und ein weiteres Plugin hinzugefügt..
- kleine weitere Veränderungen und internes..
Thx zombi
Shadow WQHD Mediaportal Skin Update: 04.01.25 v3.0-r6
- small adjustments
Shadow WQHD Skin Update: 04.01.25 v3.0-r12
- keyboard icons are now gone because the skin uses symbol fonts and no longer image icons, so if you haven't installed this RE: User for User Thread - "Fix for AIO or DreamOS Image" fix, you will only see the default icons in my skin (I am no longer backwards compatible) I just don't want that anymore because I don't want to carry anything old around with me.
- some plugin screens from gutemine's plugins are gone because he deleted them and they are no longer available to install
- new REC icon, is now on the left and looks like a download icon like the UP or load icon from the GP.
- the new circle progress with remaining running time is now in the standard channel selection and some others
- the new circle progress can also be switched in the info bar using styles under the item "Infobar Clock"
- switchable EPG long list new look + an additional EPG LOng EDM view switchable
- new switchable main menu screen (EDM banner)
- 2 switchable original movie list screens (default and EDM)
- many smaller internal things
(Online Update)
Shadow WQHD Skin Update : 30.05.25 v3.0-r29
- interne kleinere Änderungen
Thx zombi
Has thanked: 14323 times
Been thanked: 1607 times
(Online Update)
Shadow WQHD Skin Update : 05.12.25 v40-r11
- switchable timer+ dmi screen integrated
- switchable EPG selection dmi screen now with channel name on top instead of static title EPG view
- small edm channel list replaced by small dmi channel list
- internal and minor adjustments here and there
Thx zombi
Return to “Skins”
