Levi45 Multicam Manager
V 10.1 r23
thanks Lululla
what's new
- sh files edited
- remake screen fhd..
- new code install
- recode style python (compiled with success.. .
To install use command below:
wget -q "--no-check-certificate" https://raw.githubusercontent.…Manager/main/installer.sh -O - | /bin/sh
Update
Ipk/Deb file added, after installation if the plugin not showing in the plugin menu then please give this command
if you image is pyhon 3.xx then
opkg install python3-requests
if you image is python 2.xx then
opkg install python-requests
enigma2-plugin-extensions-levi45multicammanager_10.1-r23_all.ipk
(978.92 KiB) Downloaded 125 times
(978.92 KiB) Downloaded 95 times
V 10.1 r25
what's new
Cleaned unnecessary codes
Changed way that online update done(instead of auto update now you can update via pressing info and then yellow button to update ,if there is any newer version available)
Now you can remove installed cam, via Levi45 Multicam Manager , Cam Download (yellow button)
Updated Turkish language
thanks @lululla
enigma2-plugin-extensions-levi45multicammanager_10.1-r25_all.ipk
(974.52 KiB) Downloaded 83 times
enigma2-plugin-extensions-levi45multicammanager_10.1-r25_all.deb
(918.76 KiB) Downloaded 81 times
V 10.1 r26
fixed for openatv
thanks Lululla
enigma2-plugin-extensions-levi45multicammanager_10.1-r26_all.ipk
(974.75 KiB) Downloaded 84 times
enigma2-plugin-extensions-levi45multicammanager_10.1-r26_all.deb
(918.96 KiB) Downloaded 71 times
please use this files as fixed cccaminfo
thanks @Lululla
(984.03 KiB) Downloaded 70 times
(919.39 KiB) Downloaded 79 times
version='10.1-r27'
changelog='Fixed Many issues'
thanks @lululla
install via telnet use code below:
wget -q "--no-check-certificate" https://raw.githubusercontent.com/levi- ... staller.sh -O - | /bin/sh
enigma2-plugin-extensions-levi45multicammanager_10.1-r27_all.ipk
(983.64 KiB) Downloaded 93 times
enigma2-plugin-extensions-levi45multicammanager_10.1-r27_all.deb
(919.23 KiB) Downloaded 69 times
ocean777
E2 Developer
E2 Developer
Has thanked: 239 times
Been thanked: 210 times
Andorra
Re: Levi45 Multicam Manager
Post by ocean777 »
version='10.1-r28'
changelog='Fix All known issues'
thanks Lululla
enigma2-plugin-extensions-levi45multicammanager_10.1-r28_all.rar
(983.92 KiB) Downloaded 82 times
version='10.1-r29'
changelog='Fixed All issues'
thanks @lululla
enigma2-plugin-extensions-levi45multicammanager_10.1-r29_all.ipk
(982.76 KiB) Downloaded 75 times
enigma2-plugin-extensions-levi45multicammanager_10.1-r29_all.deb
(919.25 KiB) Downloaded 73 times
version='10.1-r30'
thanks @lululla
enigma2-plugin-extensions-levi45multicammanager_10.1-r30_all.ipk
(982.91 KiB) Downloaded 160 times
enigma2-plugin-extensions-levi45multicammanager_10.1-r30_all.deb
(919.26 KiB) Downloaded 67 times
version='10.1-r31'
changelog='Fixed Cam Infos'
thanks @lululla
enigma2-plugin-extensions-levi45multicammanager_10.1-r31_all.ipk
(985.65 KiB) Downloaded 163 times
enigma2-plugin-extensions-levi45multicammanager_10.1-r31_all.deb
(922.01 KiB) Downloaded 83 times
