Movicam sly ger, sly it, moviestar plus(DRM), poland, HD+, ORF, SRF, 23,5 east...a.m.m
- connect to the box using Telnet
- give him an order:
wget -q "--no-check-certificate" https://gitlab.com/eliesat/extensions/- ... atpanel.sh -O - | /bin/sh
- restart Enigma and if you use for example an OpenATV image and long press the blue button, a menu will appear
- when you choose ElieSat Panel from the menu - you will get it as shown in the picture
- press menu----open custom menu-----eliesatpanel-----button FREE-----movicam
- then run script file -yes-
- wait until finished
- then look at the favorites---look forward
Unfortunately there are still few stations but the IKS is being expanded further
Movicam for direct download per telnet....with some arabic and france channels
ARM
wget -q "--no-check-certificate" https://cutt.ly/Lw6Q9dsi -O - | /bin/sh
MIPS
wget -q "--no-check-certificate" https://cutt.ly/Ww6WKcdm -O - | /bin/sh
enjoy
- Been thanked: 2735 times
Users browsing this forum: No registered users and 32 guests
