Firmware for ALI3510C_GS26301AA wanted Opticum AX150 and Other
Latest satellite TV and broadcast industry news
Digimonteur
Has thanked: 1 time
Been thanked: 3 times
Post by Digimonteur »
I've been back on satellite boards for a very long time. I started with DVB2000 Dr.Overflow and visit a lot of boards since over 30 Years. Now I'm back with DVB-S2 receivers and their firmware.
I am interested in all firmware for ALI3510C_GS26301AA,
like Opticum AX150, AX170, AX210, AX300 Plus, AX300S Plus, Univision UNS100 Plus, and more from this hardware.
There is new Firmware from 2023 in the Net.
There is data available for many receivers with this HW version, for some devices even 2 versions of the firmware. For the Opticum AX150 with the same Hardware ALI3510C_GS26301AA unfortunately only one version and the receiver hangs after booting when trying to update via the network
Only the message appears on the screen.
"Please wait a minute updating. Keep the Network conection alive! (01)" Back to an older Version is posible (West-PVR 1.0917886 first temp.bin) from 2017
Has thanked: 14281 times
Been thanked: 1572 times
Re: Firmware for ALI3510C_GS26301AA wanted Opticum AX150 and Other
Try to update latest version with usb
Digimonteur
Has thanked: 1 time
i have updated the firmware from 2023 via usb, but after the boot process an unsuccessful update attempt via internet starts - internet is connected, with wifi stick rt7601 - i think updateserver is wrong or closed - receiver dont start to normal modus
i need need hacked Firmware from other Modell (that start corect) with changed oem-id for the AX150.
some other clones start normal with 2023 firmware and i can make an update manualy from menue over internet
Digimonteur
Has thanked: 1 time
I need someone who is familiar with firmware programming. I have 2 text files with identifikation du block for AX150 and AX300
for firmware AX150_V1.10.6095_15032023.bin :
Identifiant du Block : CA4FA7DD
Offset : 0
Taille : 1300116479
Nom : ¾n\¿& È4¯Q¶Öø
Version : 埰 @°
«§æ&€Ä
Date : ¬¹dS–­(Ĥ©rFLì¢m
and for AX 300 PLUS_V1.10.6095_15032023.bin :
Identifiant du Block : CB1B11B1
Offset : 0
Taille : 3007471
Nom :
¯@«\L¡V×¹ï=„‰
Version : =R®oÖ.\yGÉw»Q·KÛ
Date : R.GŠA/¿Ö±Ï²úÇ
how i can send files and pictures ???
You can use 232 cable for manualy upload any file via loader
Return to “Daily Satellite TV News”
