DemonEditor
DemonEditor
Enigma2 channel and satellite list editor for GNU/Linux and macOS
Experimental support of Neutrino-MP or others on the same basis (BPanther, etc). Focused on the convenience of working in lists from the keyboard. The mouse is also fully supported (Drag and Drop etc).
Main features of the program:
Editing bouquets, channels, satellites.
Import function.
Backup function.
Extended support of IPTV.
Support of picons.
Importing services, downloading picons and updating satellites from the Web.
Import to bouquet(Neutrino WEBTV) from m3u.
Export of bouquets with IPTV services in m3u.
Assignment of EPGs from DVB or XML for IPTV services (only Enigma2, experimental).
Playback of IPTV or other streams directly from the bouquet list.
Control panel (via HTTP API).
Ability to view EPG and manage timers (via HTTP API).
Simple FTP client (experimental).
Important
Support for DVB-T/T2 and DVB-C channels for Neutrino is not fully implemented and has an experimental status.
Main supported lamedb format is version 4. Versions 3 and 5 has only experimental support!
For version 3 is only read mode available. When saving, version 4 format is used instead.
When using the multiple import feature, from lamedb will be taken data only for channels that are in the selected bouquets!
If you need full set of the data, including [satellites, terrestrial, cables].xml (current files will be overwritten),
just load your data via "File/Open" and press "Save".
When importing separate bouquet files, only those services (excluding IPTV)
that are in the current open lamedb (main list of services) will be imported.
The program is tested only with openATV image and Formuler F1 receiver in Linux Mint (MATE 64-bit) distribution!
The functionality and performance of macOS version may be different from the Linux version!
Not all features can be supported and tested! Recommended copy the package to the Application directory.
Perhaps in the security settings it will be necessary to allow the launch of this application!
Windows users can also run this program. The Windows version is still experimental!
All builds may contain components distributed under the GPL v3 or lower license.
By downloading and using this packages you agree to the terms of this license and the possible inconvenience associated with this!
THIS SOFTWARE COMES WITH ABSOLUTELY NO WARRANTY.
Use this application at your own risk!
DemonEditor-Linux [zip] 3.10.2 Beta
DemonEditor-Linux [deb] 3.10.2 Beta
DemonEditor-macOS [dmg] 3.10.2 Beta
DemonEditor-3.10.2-Beta-macOS-x86-64.dmg.zip
(39.65 MiB) Downloaded 110 times
DemonEditor-3.10.2-Beta.deb
(348.45 KiB) Downloaded 71 times
DemonEditor-3.10.2-b1.zip
(759.92 KiB) Downloaded 87 times
