Xcforever 3.0
Been thanked: 2735 times
Xcforever 3.0
We can insert lines in to a xclist.txt file like this
Default Path Folder file: /etc/enigma2/xc or other folder patg configured from menu setup
Name list .txt : xclist.txt
lines type in file :
http://YOUR_HOST/get.php?username=USERNAME&password=PASSWORD&type=TYPELIST
http://YOUR_HOST:YOUR_PORT/get.php?username=USERNAME&password=PASSWORD&type=TYPELIST
TYPELIST== m3u or m3u_plus
thx Lululla
enigma2-plugin-extensions-xcplugin-forever_3.0_all.ipk
(1.13 KiB) Downloaded 130 times
enigma2-plugin-extensions-xcplugin-forever_3.0_all.deb
(1.23 KiB) Downloaded 82 times
Re: Xcforever 3.0
version='3.2'
10.10.2024
changelog='Fix Aspect on Exit Fix Downloaded Name for moviebrowser poster'
telnet:
wget -q "--no-check-certificate" https://raw.githubusercontent.com/Belfa ... staller.sh -O - | /bin/sh
Re: Xcforever 3.0
v. online 3.3
12.10.2024
Telnet:
Re: Xcforever 3.0
new update, 2 more days of code.
-fix all global name
-fix major on player utility and download movie
-fix screen -removed major code unnecessary
-simplyfied def and var witj I.E.
v.3.4 is online
enigma2-plugin-extensions-xcplugin-forever_3.4_all.ipk
(1.45 MiB) Downloaded 69 times
enigma2-plugin-extensions-xcplugin-forever_3.4_all.deb
(1.24 KiB) Downloaded 59 times
Re: Xcforever 3.0
v.3.5 is online
enigma2-plugin-extensions-xcplugin-forever_3.5_all.ipk
(1.12 KiB) Downloaded 46 times
enigma2-plugin-extensions-xcplugin-forever_3.5_all.deb
(1.23 KiB) Downloaded 60 times
Re: Xcforever 3.0
For those who have already installed or updated to version 3.5, please do a forced upgrade from lplugin
Info_Long or yellow_long
-fix issue on playlist select
-fix- removed major code
Re: Xcforever 3.0
V.3.6 is Online..
BACK TO CATEGORY LIST
Fix DreamOS System for Unicode List
EPG Fixed(tmdb/imdb/showInfo)
All code unecessary removed
Add Module import
enigma2-plugin-extensions-xcplugin-forever_3.6_all.ipk
(1.12 KiB) Downloaded 47 times
enigma2-plugin-extensions-xcplugin-forever_3.6_all.deb
(1.23 KiB) Downloaded 46 times
Re: Xcforever 3.0
a new version are here
v.3.7
-Fix skin with OeNewEnigma
-Move Module import
enigma2-plugin-extensions-xcplugin-forever_3.7_all.ipk
(1.2 KiB) Downloaded 51 times
enigma2-plugin-extensions-xcplugin-forever_3.7_all.deb
(1.3 KiB) Downloaded 43 times
Re: Xcforever 3.0
v.3.8
17.12.2024
changelog:
Move All Module
Recoded all code
Code:
wget -q --no-check-certificate https://raw.githubusercontent.com/Belfa ... staller.sh -O - | /bin/sh
Re: Xcforever 3.0
v.3.9
31.12.2024
thx Lululla
telnet code:
Return to “IPTV Free m3u Playlists”
Users browsing this forum: cabbar64 and 16 guests
