How to Backup and Install New Images
Enter Recovery Mode
To begin, you’ll need to enter the recovery mode on your Enigma2 box. This can typically be done by pressing a specific button combination on your remote control. Once in recovery mode, you’ll have access to the necessary tools to create your backup.
Initiating the Backup Process
From the recovery mode menu, navigate to the option to create a backup image. Your Enigma2 box will then prompt you to select the location where you want to save the backup file. This could be an external hard drive, How to Backup and Install New Images USB drive, or SD card connected to your device.
Once you’ve selected the desired storage location, the backup process will commence. Depending on the size of your current image, this may take several minutes to complete. Be patient and allow the process to finish without interruption.
https://huntersam.online/how-to-backup- ... igma2-box/
- dreamworld
- Has thanked: 2 times
- Been thanked: 35 times
