Customizing Your Windows 11/10 Boot Logo A Step-by-Step Guide
dreamworld
Has thanked: 2 times
Been thanked: 35 times
United Arab Emirates
Post by dreamworld »
Customizing Your Windows 11/10 Boot Logo Disabling Secure Boot
Customizing Your Windows 11/10 Boot Logo A Step-by-Step Guide Before we begin, it’s important to ensure that Secure Boot is disabled on your computer. Secure Boot is a security feature that helps protect your system from malware, but it can also prevent us from making changes to the Windows bootloader, which is necessary for customizing the boot logo. To check if Secure Boot is disabled, open the System Information tool (search for “msinfo32” in the Windows search bar) and look for the “Secure Boot State” field. If it says “On,” you’ll need to restart your computer, enter the BIOS, and disable Secure Boot.
Verifying UEFI BIOS
In addition to disabling Secure Boot, your computer’s BIOS mode must be set to UEFI (Unified Extensible Firmware Interface) in order to change the boot logo. You can check your BIOS mode in the System Information tool as well. If your BIOS mode is set to Legacy, your computer may be too old to support UEFI, or you may need to reinstall Windows in UEFI mode, which is generally not worth the effort just to change the boot logo.
https://huntersam.online/customizing-yo ... boot-logo/
