[Plugin] EventDataManager
- ocean777
- Has thanked: 239 times
- Been thanked: 210 times
plugin eventdatamanager v1.0-r19
New update:02.06.2024
Thx @zombi
Thx @zombi
- enigma2-plugin-extensions-eventdatamanager_1.0-r19_all.rar
- (123 Bytes) Downloaded 126 times
- ocean777
Event Data Manager For DreamOS
New update:08.06.2024
Thx @ZoMbi
- enigma2-plugin-extensions-eventdatamanager_all-v1.0-r19.rar
- (556.54 KiB) Downloaded 84 times
- ocean777
Event Data Manager v1.0-r20 For DreamOS
New update:28.07.2024
- enigma2-plugin-extensions-eventdatamanager_all_v1.0-r20_.rar
- (557.15 KiB) Downloaded 104 times
v1.0-r21 (17.08.24)
- in the EventView in the EMC, the "More..." menu on the red button is now available
- fix: in some cases an EventImage was not displayed after downloading (especially in the Second Infobar)
- internal optimizations
- extended log output for Picload errors and log output of the skin widget parameter value for "widgetName" (if specified in the skin - the log output for this widget can be filtered using grep to the specified name - makes troubleshooting easier if problems occur)
- default_title_links.json extended
PS.
Anyone who uses the EDM data in the skin for the Secondinfobar should now have the images directly when calling it (please test in a skin that offers this).
I've been testing this in my ShadowWQHD for several days now and it has improved a lot and you always have images on the screen when available without having to switch back and forth or restart the service like before.
thanks zombi
PS.
thanks zombi
- enigma2-plugin-extensions-eventdatamanager_all_1.0-r21.deb
- (557.95 KiB) Downloaded 106 times
Re: [Plugin] EventDataManager
v1.0-r22 (31.08.24)
- improved title cleanup for the search (the EPG title occasionally contains special spaces that prevented a successful search)
- fix Renderer: the Picons were sometimes no longer displayed
- fix Converter: the rating stars were sometimes no longer displayed
- default_title_links.json expanded
thanks zombi
thanks zombi
- enigma2-plugin-extensions-eventdatamanager_all.deb
- (558.21 KiB) Downloaded 121 times
Event Data Manager v1.0-r19 For DreamOS
New update14.09.08.2024
Changelog: vv1.0-r23
- im EventView wird jetzt "Entferne Timer" auf grün für Partnerbox-Remote-Timer unterstützt
- fix Renderer: in seltenen Fällen wurden die Picons nicht angezeigt
- fix Renderer: die Picons werden jetzt immer mit scale="aspect" angezeigt, da Picons mit abweichenden Abmessungen sonst nicht immer passend angezeigt wurden
- neue Setup-Option "zeige Event als Backdrop-Fallback" (so kann unabhängig vom Skin mit dem EDM-Image-Renderer automatisch ein vorhandenes Event-Image angezeigt werden, falls ein Backdrop nicht vorhanden ist)
- neue Setup-Option "zeige neuesten Treffer (wenn kein Jahr im EPG)" (damit wird bei mehreren Treffern zu einem Titel, der neuere Treffer bezüglich der Jahresangabe von TMDB verwendet - bisher wurde immer der älteste Eintrag angezeigt)
- wenn das EventView aus dem Live-TV oder aus der Kanalliste aufgerufen wird, kann man jetzt mit den Tasten "<" "0" ">" in den Events springen ("<" ">"
- springe einen Tag/24h zurück/weiter, "0" - springe zum PrimeTime-Event des Tages des Events, welches gerade angezeigt wird)
- in der EDM-Suche kann man nun mit "blau lang" bei "Suche anpassen" wieder den ursprünglichen Suchtext zur Suche verwenden
- neues Text-Widget "searchtext" in der EDM-Suche zur Anzeige des aktuellen Suchtextes im EventDataManagerTMDBsearch-Screen (als Zusatzinfo wird in Klammern dabei Serie bzw. Movie und ein evtl. vorhandenes Film-Jahr aus dem EPG-Text angezeigt - die Zusatzinfo wird aber im EventDataManagerTMDBsearch-Screen bei der Suche nicht verwendet)
- verbesserte Film-Jahr-Erkennung aus dem EPG-Text
- default_title_links.json erweitert..
Thx zombi
Thx zombi
- enigma2-plugin-extensions-eventdatamanager_v1.0-r23_all.rar
- (560.01 KiB) Downloaded 102 times
v1.0-r24 (04.10.24
- new web image search (Bing or Google can be selected as standard in the setup or in the TMDB search menu) - this allows alternative images to be searched for and saved
- new logos in the search result display in the TMDB search - skinnable via TemplatedMultiContent (3 different logos show whether the TMDB search result is already saved in the local DB or the data in the local DB is out of date or the entry is not yet saved in the local DB)
- in the TMDB search menu, an existing event image or saved content images (backdrop/cover/logo) can now also be deleted (this was previously only possible for the event fallback image)
- in the TMDB search, "removal" from the content data is now supported on "green" in addition to "add" (previously this was only possible in the content manager)
- in the TMDB search menu you can now also display the links for the selected entry (previously this was only possible in the content manager)
- the image renderer now also takes into account a local content image (backdrop/cover/logo) for a suitable DB entry, even if there is no content image stored in the DB entry in TMDB
- when deleting a DB entry in the content manager, the associated locally stored content images are now also deleted
- duplicate DB links can now also be deleted individually (previously, when deleting an entry, all identical/duplicate DB links were automatically deleted)
- fix renderer: the picons were no longer displayed when recording
- new depends packages in the plugin installation package (python-imaging, python-beautifulsoup4)
thanks zombi
thanks zombi
- (570.08 KiB) Downloaded 114 times
v1.0-r25 (20.10.24)
- neue Setup-Option zum De-/aktivieren der Partnerbox-Fehlermeldung im EventView (somit kann die Fehlermeldung im EventView unterdrückt werden, wenn z.B. die eingerichtete Partnerbox nicht online ist)
- neue Menü-Optionen in der Verknüpfungsliste
* "aus DB-Verknüpfung eine json-Verknüpfung erstellen" - um diese dann als json bearbeiten zu können
wenn man eine eigene default_title_links.json in "/etc/enigma2/" nutzt, auch diese Punkte:
* "User-json mit default-json aus Plugin-Ordner zusammenführen" (z.B. nach einem Update der default-json im Plugin-Ordner)
* "zeige eigene json-Einträge", welche nicht in der default-json im Plugin-Ordner enthalten sind
- in der Verknüpfungsliste können nun mit "grün" json-Verknüpfungen bearbeitet werden
- in der Verknüpfungsliste kann man nun wie im Content-Manager mit den Zahlentasten alphabetisch zu den Einträgen navigieren
- wenn in der Suchliste der Titel zu einem Treffer in der DB geändert wird (Anzeige über gesondertes Symbol), dann wird nun auch eine dazugehörige vorhandene DB-Verknüpfung entsprechend angepasst
- in der Suchliste wird im Menü für den Menüpunkt "zeige Verknüpfungen für ausgewählten Eintrag" nun auch eine json-Verknüpfung berücksichtigt (bisher nur DB-Verknüpfungen)
- neuer compare_type "regex" für die default_title_links.json (damit können variable EPG-Texte noch besser verknüpft werden, ".*" als Platzhalter für variablen Text, "^bla" Text beginnt mit "bla" und "bla$" Text endet mit "bla")
- (571.93 KiB) Downloaded 111 times
v1.0-r27 (19.01.25)
- fix für fehlende EDM
-Images in der EPGSelection in Version r26
thanks zombi
thanks zombi
- (572.06 KiB) Downloaded 103 times
- 1925 Views
- 1320 Views
- 1165 Views
- 3061 Views
Last post by gregor1213
- 868 Views
