Wenn Ihr das alles installiert habt dann, in den Plugins das AjPanel öffnen
Die Menü Taste drücken und dann auf Open Customv Menu anklicken
Es öffnet sich ein Fenster wo ganz oben ElieSatPanel steht daruf klicken
Dann öffnet sich das ElieSatPanel dort könnt Ihr dann verschiedene Sachen downloaden
Da findet Ihr auch eine Rubrik Free da könnt Ihr Playlists und Portals runterladen
Plugins AjPanel + Eliesatpanel .3.1
- Plugins AjPanel +Eliesatpanel +Info und wget install per Terminal.rar
- (21.6 MiB) Downloaded 463 times
- ocean777
- Has thanked: 239 times
- Been thanked: 210 times
Re: Plugins AjPanel + Eliesatpanel .3.1
Ajpanel_v9.4.0
- Added new option "Move Selected Item" to Custom Menu (to change the position of items in main menu).
- Added "General Guide" to main page menu to show some AJPanel general help.
- Improved AJPanel Update to internally use the new URL ( https://github.com/AMAJamry/AJPanel ).
.. The file "ajpanel_update_url" is no longer needed for the update process.
- Added the option "EPG Events Counter" to EPG Page (to count the events for all DVB & IPTV channels).
- Improved "M3U/M3U8 File Browser":
.. To play M3U/M3U8 files that contain DVB channels and Local media files.
.. To show current file name in INFO.
- Improved File Manager to handle ".m3u" files in "M3U/M3U8 File Browser" (instead of trying to play it).
- Improved IPTV Favourite menu items to show server host when Menu button is clicked.
- Improved reading portal Host/MAC from files wih more formats.
- Improved skipping atvs channels and categories.
- Improved "XML-TV Tools".
.. Improved the Green Button to pick a Channel-Reference file (if file is not initially set).
.. Improved the process to cache the total tags per XML file (for faster process).
- Improved PIcons page (Green Button) to locate the current PIcon (if current channel name is used as file name).
- Improved "Restore" pages:
.. Added "Rename" (Blue Button) to partially rename backup files.
.. Added INFO Button to show selected file information.
- Improved Player Bar option ("Start Download") to be available for some URL structures.
- Improved "Dev. Info." >> "Settings File" data to be tabulated.
- Fixed Portal Files Editor to point to the current line number.
- Fixed portal download from tables options "Download Current Movie" and "Download Current Series".
- Fixed the problem of showing "Processing ..." followed by no action.
- Fixed a crash on VTi (in File Manager) when browsing a directory with file extension ".7z" or ".7".
- Fixed File Manager Multi-Select counter (when selecting/unselecting all).
Thx @ Biko_73
- enigma2-plugin-extensions-ajpanel_v9.4.0_all.ipk.zip
- (478.61 KiB) Downloaded 226 times
- 122 Views
