Settings for Images based on Android FW's:
Statistics:
# Clarke Belt covered: 47.5°W - 76.5°E
# Satellites: 87 (Ku Band TP + DTV Freq. Lists)
# Services: 16.781
# Ordered Provider Lists: 55
It's a full channel list for Amiko A5/A4/A6 Android FW's...
- New Extended TP Table (full scan required)
- Added Parental Control Flags (The default password is ‘0000’)
Instructions: FTP/Overwrite the file prog.db into /data/data/com.linkdroid.home/databases folder.
Since it's the first channel list available for these decoders, any feedback, suggestion, integration, correction and support (and a simple "Thanks") is very important and greatly appreciated
=== Compiled with Morpheus883's scripts ===
======= © by Morpheus883, 2024 =======
