I would like to request for stalker portal player for pc
hasmevask
Been thanked: 5 times
India
Post by hasmevask »
Hi,
I would like to get this stalker portal player for windows
https://tinypic.host/image/photo-2024-0 ... -45.DKGdJ2
kindly share thanks
Has thanked: 14363 times
Been thanked: 1661 times
Re: I would like to request for stalker portal player for pc
hasmevask wrote: ↑25 May 2024, 12:23 Hi,
kindly share thanks
Stalker Portal Player V 7.1 for windows
https://ia601606.us.archive.org/10/items/stalker-portal-player-v-7.1/stalker%20portal%20player%20v7.1%20czysty%20clean.zip
hasmevask
India
Post by hasmevask »
Thank your for replay and help
But image ( software) I requested is Different player and this player is different
hasmevask wrote: ↑25 May 2024, 12:34 Thank your for replay and help
https://uloz.to/file/jnPuSKhVarfm/stalker-portal-player-for-pc-v3-0-final-rar
please try this IPTV Stalker Player on Windows Pc
https://napkforpc.com/apk/np.pro.dipendra.iptv/
hasmevask
India
Post by hasmevask »
The Founder wrote: ↑25 May 2024, 12:41
File does not exist
this is also broken link
hasmevask
India
Post by hasmevask »
Hannibal_Lecter wrote: ↑25 May 2024, 12:45 please try this IPTV Stalker Player on Windows Pc
Thanks
it shows download option for pc -- but it gives apk only
it ask for bluestack to use too for apk
I need portable exe player not bluestack needed as it consume more ram on pc
maybe this will be good
https://sfvipplayer.com/
hasmevask
India
Post by hasmevask »
Hannibal_Lecter wrote: ↑25 May 2024, 13:49 maybe this will be good
That do have too , thanks for the suggestion and link though
if possible to get the image link posted on 1st post will be great
xixogo5105
Been thanked: 1 time
New Caledonia
Post by xixogo5105 »
why not give a try to java based windows open source stalker portal?
you can download it at: https://github.com/xixogo5105/uiptv/rel ... uiptv-logo
or alternatively you can install maven and compile the code yourself.
you must install java 17 (preferably JDK) and set its home to windows path. all instructions are available at https://github.com/xixogo5105/uiptv
to run it, create a bat file (or vbs file) with the following command:
cd ~/uiptv && java --module-path ./lib --add-modules=javafx.controls -jar ./UIPTV.jar
Thats it!
its open source solution so know that once you figured out how to run it and play, there is no more need of installing files from the random dodgy websites.
give it a try and start enjoying streaming in your favourite windows video player. my personal favourite is mpv.
