7-Zip
Been thanked: 2735 times
7-Zip
7-Zip v24.05
New Update:14.05.2024
- New switch -myv={MMNN} to set decoder compatibility version for 7z archive creating.
{MMNN} is 4-digit number that represents the version of 7-Zip without a dot.
If -myv={MMNN} switch is specified, 7-Zip will only use compression methods that can
be decoded by the specified version {MMNN} of 7-Zip and newer versions.
If -myv={MMNN} switch is not specified, -myv=2300 is used, and 7-Zip will only
use compression methods that can be decoded by 7-Zip 23.00 and newer versions.
- New switch -myfa={FilterID} to allow 7-Zip to use the specified filter method for 7z archive creating.
- New switch -myfd={FilterID} to disallow 7-Zip to use the specified filter method for 7z archive creating.
- Some bugs were fixed.
https://www.7-zip.org/download.html
7-Zip
7-Zip v24.06
New Update:26.05.2024
- The bug was fixed: 7-Zip could not unpack some ZSTD archives..
7-Zip
7-Zip v24.07 was Released
New Update:19..06.2024
- The bug was fixed: 7-Zip could crash for some incorrect ZSTD archives..
7-Zip
7-Zip v24.08
New Update:11.08.2024
HISTORY of the 7-Zip v24.07
- The bug in 7-Zip 24.00-24.08 was fixed:
For creating a zip archive: 7-Zip could write extra zero bytes after the end of the archive, if a file included to archive cannot be compressed to a size smaller than original.
The created zip archive is correct except for the useless zero bytes after the end of the archive.
When unpacking such a zip archive, 7-Zip displays a warning:
"WARNING: There are data after the end of archive".
- The bug was fixed: there was a leak of GDI objects (internal resources in Windows)
in "Confirm File Replace" window, causing problems after 1600 displays of "Confirm File Replace"
window from same running 7-Zip process.
- Some optimizations for displaying file icons in 7-Zip File Manager and in "Confirm File Replace" window.
Re: 7-Zip
7-Zip v24.09
New Update: 29.11.2024
HISTORY of the 7-Zip 24.09
- The default dictionary size values for LZMA/LZMA2 compression methods were increased:
dictionary size compression level
v24.08 v24.09 v24.09
32-bit 64-bit
8 MB 16 MB 16 MB -mx4
16 MB 32 MB 32 MB -mx5 : Normal
32 MB 64 MB 64 MB -mx6
32 MB 64 MB 128 MB -mx7 : Maximum
64 MB 64 MB 256 MB -mx8
64 MB 64 MB 256 MB -mx9 : Ultra
The default dictionary size values for 32-bit versions of LZMA/LZMA2 don't exceed 64 MB.
- 7-Zip now can calculate the following hash checksums: SHA-512, SHA-384, SHA3-256 and MD5.
- APM and HFS support was improved.
- If an archive update operation uses a temporary archive folder and
the archive is moved to the destination folder, 7-Zip shows the progress of moving
the archive file, as this operation can take a long time if the archive is large.
- The bug was fixed: 7-Zip File Manager didn't propagate Zone.Identifier stream
for extracted files from nested archives (if there is open archive inside another open archive).
Download 7-Zip v24.09-(2024-11-29)
