E2 SAT Editor
E2 SAT Editor
e2 SAT Editor - Yet another channel list editor
NEW version 1.4 released
Fix FTP issues [Windows]
Fix reading files with end of line CRLF [Windows]
Fix add favourite, stream type
Fix edit transponder
Fix merge, clear XML comments
Fix reference ID and marker number
Revised transponder feparams
Win11 initial support [Windows]
Prevent crashes
It can edit settings list, Enigma, Neutrino, in their various versions. It comes with FTP, telnet and webif support.
No special features, it only edits lists. It consists of 1 drag-and-drop tree view, has tab navigation, there is transponders editor, xml settings editor, a channel explorer "Channel Book" with channels by categories: services, bouquets, positions, providers, resolution, encryption, A-Z.
It has tabbed navigation with global Cut-Copy-Paste support; Drag and Drop support; import and export of Lamedb, bouquets and userbouquets; FTP support; tools for sorting and management of channel lists; non-destructive editing; dark and light themes.
Now with built-in Picons editor!
It supports both Enigma2, Lamedb 4 and Lamedb 5 formats (2.4 and 2.5) and Enigma1 (2.3 and 2.2).
And it supports also Neutrino xml (api v1, v2, v3, v4).
https://github.com/ctlcltd/e2-sat-edito ... tag/v1.4.0
e2se-cli-1.4.0-test-x86_64-linux.zip
(734.5 KiB) Downloaded 134 times
e2-sat-editor-1.4.0-x86_64-linux.zip
(37.82 MiB) Downloaded 112 times
e2-sat-editor-1.4.0-user-manual.zip
(83.04 KiB) Downloaded 85 times
e2-sat-editor-1.4.0-unsigned-win64.zip
(37.38 MiB) Downloaded 146 times
e2-sat-editor-1.4.0-unsigned-win32.zip
(36.97 MiB) Downloaded 94 times
e2-sat-editor-1.4.0-unsigned-test-silicon-macos.zip
(38.4 MiB) Downloaded 85 times
e2-sat-editor-1.4.0-unsigned-intel-macos.zip
(40.05 MiB) Downloaded 96 times
E2 SAT Editor
NEW version 1.6 released
Changelog​
Fix crash with empty service parameters on save
Fix parental lock on write
Fix a buffer overflow when parsing userbouquet service flag
Added support for 519 bouquet hidden
Fix soft errors when listing with FTP command NLST
Added cross-platform support for CRLF end line on read
Fix end line from CRLF to LF on write [Windows]
Added button to calculate DVBNS transponder
Improved merge
Fix tree highlight color theme bugs [Windows]
Updated translations
Github and Download
https://github.com/ctlcltd/e2-sat-editor/releases
