CoolExtra (Plugin for customizing CoolTVGuide V7.7 OE2.0)
MyFriendVTI wrote
With CoolExtra, the CoolTVGuide V7.7 OE2.0 plug-in can be customized as follows:
Button assignment / CoolInfoBox:
Plugin - TMDb
AEL-Editor (Advanced-Event-Library)
Plugin - Serial recorder
Plugin - AutoTimer (CoolInfoBox only)
Action: PVR/Video button
Action: Power button
CoolTVGuide customizations:
Center picons horizontally
Draw frame around picon
Deactivate limit picon line height
Scale line backgrounds
CoolInfoGuide customizations:
NextEvents: Move line content vertically (+/-)
CoolExtra does not change the installed CoolTVGuide plugin!
If no options are activated in CoolExtra or CoolExtra is uninstalled, the CoolTVGuide plugin can be used as usual in its original state.
Notes:
The red button cannot be assigned to a plug-in
If a plug-in has been assigned to a button with CoolExtra, this button cannot be reassigned in the CoolTVGuide settings.
Only when the button has been released again in the CoolExtra settings is reassignment possible again
If there is an AEL image in CoolTVEPG and the AEL editor is opened and closed, the CoolExtra log can be used to track which image files were searched for for the AEL image display
[E² Plugin] CoolExtra
- Has thanked: 14360 times
- Been thanked: 1669 times
Update-Info V1.2
-The plugin TV-Spielfilm-Viewer can optionally be added to a button or to the CoolInfoBox to retrieve data about a selected program from TV-Spielfilm
Thanks VTI
Thanks VTI
- enigma2-plugin-extensions-coolextra_1.2_all.ipk
- (18.71 KiB) Downloaded 166 times
Re: [E² Plugin] CoolExtra
Update info V1.3
Call from AEL Editor adapted to AEL R145 to find TV movie covers
Note:
CoolExtra continues to work only with CoolEPGGuide V7.7
Thanks VTI
Note:
Thanks VTI
- enigma2-plugin-extensions-coolextra_1.3_all.ipk
- (18.72 KiB) Downloaded 62 times
- 3653 Views
Last post by gregor1213
- 1110 Views
- 857 Views
- 679 Views
- 768 Views
