Program version: 11.03 Final
Official website address: Ghisler Software GmbH
Interface language: Russian, English, and others
Treatment: Included (license file)
Total Commander
- ocean777
- Has thanked: 240 times
- Been thanked: 210 times
Total Commander
Total Commander 11.03 Final (2024) PC
- Total Commander 11.03 Final.rar
- (20.78 MiB) Downloaded 174 times
Re: Total Commander
Total Commander 11.50B6 (x32/x64)[Full] + Portable
Features in Total Commander 11.50B6 now include :
Two file windows side by side
Multiple language and Unicode support
Enhanced search function
Compare files (now with editor) / synchronize directories
Quick View panel with image and video display
ZIP, 7ZIP, ARJ, LZH, RAR, UC2, TAR, GZ, CAB, ACE archive handling + plugins
Built-in FTP client with FTPS (encrypted FTP) and HTTP proxy support
Multi-rename tool
Tabbed interface, regular expressions, history+favorites buttons
Thumbnails view, custom columns
Compare editor, cursor in lister, separate trees, logging, enhanced overwrite dialog etc.
Unicode names almost everywhere, long names (>259 characters), password manager for ftp and plugins, synchronize empty dirs, 64 bit context menu, quick file filter (Ctrl+S)
USB port connection via special direct transfer cable, partial branch view (Ctrl+Shift+B), and many improvements to ftp, synchronizing and other functions
And many more!
Download
https://fastupload.io/9a489c53ea99c903
Multi-rename tool
And many more!
Download
Re: Total Commander
Total Commander 11.50RC3 (x32x64)[Full] + Portable
Total Commander 11.50RC3 (x32x64)[Full] + Portable.rar
https://www.satworld-forum.com/download ... hp?id=6969
Re: Total Commander
Total Commander 11.50 Final
02.01.25 Release Total Commander 11.50 official release
29.12.24 Fixed: Button bar, start menu: Do not remove any leading duplicate backslashes from names in fields %S, %P%O, %P%S etc., e.g. after searching in UNC path (32/64)
29.12.24 Fixed: Verify checksums: show error if checksum file is larger than 2GB (32/64)
26.12.24 Fixed: Lister, dark mode: Main menu was shown in light mode when showing multiple files and switching from a file shown as plain text to a file shown with a plugin (32)
26.12.24 Fixed: Lister, dark mode: "Options" submenu was displayed incorrectly when option 8 (Explorer preview) was hidden (32)
26.12.24 Fixed: Compare by content, binary mode: clicking on Next difference, previous difference, next difference stayed on the first difference if the files started with a different line (32/64)
https://www.ghisler.com/download.htm
Re: Total Commander
Total Commander 11.51 Final (2024) PC
Install the program
Delete wincmd.key, if any, from the program folder.
Copy wincmd.key to the folder with the installed program.
Total Commander 11.51 Final.rar
https://www.satworld-forum.com/download ... hp?id=8111
Install the program
Re: Total Commander
Total Commander 11.55
25.06.25 Release Total Commander 11.55 official release
25.06.25 Added: Updated unrar dll to version 7.12 (32/64)
22.06.25 Fixed: Find files, Plugins tab: The sorting buttons now have the same height as in the View Mode configuration dialog (32/64)
22.06.25 Fixed: Lister: Clicking behind a line of text while a context menu was up selected the line break behind that line (32/64)
22.06.25 Fixed: Sparse file copying is now disabled by default because Windows' handling of sparse files has serious issues that can only be fixed by Microsoft. Add CopySparseFiles=1 to the wincmd.ini [Configuration] section to enable this feature (32/64)
20.06.25 Fixed: Multi-rename tool: Couldn't move up last item with drag&drop since RC6 (32/64)
20.06.25 Fixed: Properties of files in archives: Invalid time was shown for files which had no time stored (32/64)
20.06.25 Fixed: RAR archives: Invalid time was shown instead of a question mark for files which had no time stored (32/64)
32-bit version only (Windows 95 up to Windows 11, runs on 32-bit AND 64-bit machines!)
64-bit version only (Windows XP up to Windows 11, runs ONLY on 64-bit machines!)
64-bit+32-bit combined download (Windows 95 up to Windows 11, 32-bit AND 64-bit machines!)
- 8 Replies
- 1274 Views
Last post by MarsCccam
