softsatip
Search
VIARK: OPEN SKY AND VIP CHANNELS IN PT EMU
22/12/2022
2 minutes to read
As we know, Viark boxes can open Sky Germany, Sky UK and many newer special top channels coming soon. In order to do so, you needed recently released SP1 and SP2 codes because the default service of PT cannot open those special channels (can open many in all satellites, but not the most special ones)
However, Team PT has developed a system to convert the default PT service to SKY supported service, which means that you can have Sky and other top new channels with the default service in the box, so you do not need to buy extra codes
First of all, it is important to know that you only have 6 months to change from normal PT service to SKY special service. After the 6 months of the activation, you cannot do this change, you will have to buy new SP1 or SP2 code to have Sky and VIP channels
You can do the change in all new boxes after activation, but also in renewed boxes with older codes (those used before SP1 and SP2). It works for all models of Viark: SAT, SAT4K, DRS2, DROI, COMBO, DRS, LIL
(If you renewed in the recent months or renew now, you will get Sp1/Sp1 so Sky channels already included, so you do not need to do anything)
This change can only be applied once, there is no going back so be sure you want these special top channels because the service time will decrease
in Sky VIP mode, there is a decrease of CS service time because that service is more expensive, so the expiration of the service will be different as compared to the default PT service.
Viark Sat will become 12 months CS time and 12 months IPTV.
Viark Sat4K will become 24 months CS time and 12 months IPTV
VIARK SAT AND VIARK SAT4K HAVE BECOME MORE FLEXIBLE IN THEIR USE SINCE CAN BE USED WITH NORMAL PT IN SOME MARKETS, ALSO FOR SKY AND OTHER VIP CHANNELS IN OTHER MARKETS, AND ALSO FOR IPTV ONLY BECAUSE IPTV TIME IS 12 MONTHS , SO VIARK SAT HAS A GOOD PRICE FOR THE USERS WHO WANT ONLY IPTV
Now, I will describe the process to change to SKY VIP mode:
1. You need the “SN” and “verification number “of the box you want to do this change of service, you will find in this menu:
Preview
2. Paste the SN(12 digits) and verification number (4 digits) in this link in the marked red parts: http://resetsky.ddns.net:3000/skyreset? ... RIFICATION
(It is necessary to understand it is not a website, it is only a link that is edited with the SN and Verification number of your box to be copied in a Web browser to activate it in that way)
3. Copy the link with your SN and verification code in a Web Browser and press ENTER and the service will be changed automatically by doing that, you will have new Sky mode, the browser will indicate the new service time of CS and IPTV
(If you have already applied the change, the browser will show you ERROR message: Error,this SN has changed one time, cannot change it again)
Enjoy SKY channels and much more coming soon, plus longer IPTV service in Viark boxes.
