OBS Studio
Been thanked: 1092 times
OBS Studio
OBS Studio 30.1.1
24-03-2024
Description
OBS Studio (also known as Open Broadcaster Software ) is a free and open source software for video recording
and live streaming. Record everything from your monitor/screen/window or camera/capture card and live stream
or save to your HDD as MP4/MKV. High performance real time video/audio capturing and mixing, with unlimited
scenes you can switch between seamlessly via custom transitions. Filters for video sources such as image
masking, color correction, chroma/color keying, and more.
Changelog:
Fixed a crash on macOS 11 when starting OBS [PatTheMav/RytoEX]
Fixed missing HDR metadata for certain encoders [derrod]
Fixed broken hardware decoding of remote streams in Media Sources [pkviet]
Fixed broken file output from remuxing a file with PCM audio [derrod]
Fixed an issue where macOS Audio Capture or macOS Screen Capture sources could stop capturing [jcm93]
Fixed an issue on Windows causing Virtual Camera and 32-bit Game Capture to fail [PatTheMav]
Fixed an issue on Linux which caused QSV encoders to be enabled on systems with no Intel GPUs [kkartaltepe]
Backported xdg-data metadata updates [GeorgesStavracas]
Download Here:
OBS Studio 30.1.1 [127 MB]
https://www.videohelp.com/download/OBS-Studio-30.1.1-Full-Installer-x64.exe
Re: OBS Studio
OBS Studio 30.2.3
27-09-2024
Description
Changelog:
Fixed a possible deadlock when using Hybrid MP4 [derrod/notr1ch]
Fixed a possible deadlock when closing OBS while outputs are active [derrod]
Fixed a possible crash when connecting to an RTMP server [notr1ch]
Fixed a possible RTMP disconnect/timeout on Windows systems without IPv6 connectivity when connecting to a dual-stack RTMP server [notr1ch]
Fixed browser source custom CSS injection for sites with 'require-trusted-types-for' CSP (e.g., YouTube) [vvto33]
Adjusted IPv4/IPv6 address selection to be stricter [notr1ch]
Fixed a memory leak with the volume sliders [pkviet]
Download Here:
OBS Studio 30.2.3 - 133MB
https://www.videohelp.com/download/OBS-Studio-30.2.3-Windows-Installer.exe
