Oscam Mipsel (DM500HD,800,7025,8000 & VU)
Been thanked: 1668 times
Changeset 11747​
fixed CMake warnings on Debian 11
build juli13
oscam-11747-mipsel.zip
(1.07 MiB) Downloaded 145 times
Changeset 11748 with EMU-799​
fix whitespaces thanks to Optimum Power
build juli13
oscam-11748-mipsel-EMU.zip
(1.18 MiB) Downloaded 138 times
oscam-git11782-801@04b2c87e-mipsoe20-webif-dvbapi-emu
[email protected]
(733.82 KiB) Downloaded 85 times
oscam-git11787-801@64b92740-dream_mipsel-webif-dvbapi-libdvbcsa-emu-icam-upx (etc/tuxbox/config)
for dreambox 500hd/800hd/7020hd
thx Shahrooz
oscam-git11787-801@64b92740-dream_mipsel-webif-dvbapi-libdvbcsa-emu-icam-upx.zip
(721.49 KiB) Downloaded 77 times
dreambox500hd/520hd/800hd/7020hd
oscam-git11790-801@687cad71-dream_mipsel-webif-dvbapi-libdvbcsa-emu-icam-upx
oscam-git11790-801@687cad71-dream_mipsel-webif-dvbapi-libdvbcsa-emu-icam-upx.zip
(720.9 KiB) Downloaded 64 times
Oscam 11805 with EMU and Streamrelay
Revert "Send EMM of multiple CAIDs to remote readers"
This reverts commit 608d3ffb.
build juli13
oscam-11805-mipsel-EMU.zip
(974.89 KiB) Downloaded 63 times
Oscam 11807-EMU with streamrelay enable and static Libdvbcsa
Changeset 11806 (eb84d4e2)
Fix 'get_emm_type() returns error' on HD05 and fix CAK7 shared emm
* Fix Tivusat and NC+ shared EMM..
* Fix 'get_emm_type() returns error' on HD05..
* Auto detect CAK7 EMM CAID from card response..
Changeset 11807 (902f2a65)
- Fix impossible to compile without READER_NAGRA_MERLIN..
build juli13
oscam-11807-mipsel.zip
(872.76 KiB) Downloaded 78 times
Oscam-EMU Mipsel (DM500HD,800,7025,8000 & VU)​
Oscam 11807 with streamrelay enable and static Libdvbcsa
build juli13
oscam-11807-mipsel-EMU.zip
(925.22 KiB) Downloaded 69 times
Oscam 11810 ​
Protocols:
CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE GBOX CONSTCW STREAMRELAY
11808-f5163e19
Formatting some of CAK7 codes
* Fix trailing whitespaces
* Formatting some of CAK7 codes
11809-5aa10f8b
Minor CMakeLists.txt cleanup
Changeset 11810 (2d0e3aca)
README.config cleanup
* Update README.config..
build juli13
oscam-11810-mipsel.zip
(1.24 MiB) Downloaded 67 times
Oscam 11812
Protocols:​
​​Changeset 11811 (c04157c1)
Introduce upx compression support
* support for upx compression of oscam binary after build (new option `USE_COMPRESS` default off)..
* support for upx compression level adjustment (new option `COMP_LEVEL` default --best)..
* buildlog shows upx version, compression level, build date..
* additional entry for build date in oscam.version file..
* gitlab pipeline installs upx binary automatically and uses upx compression for native make/cmake test builds..
11812-6e874d2d
Fix IPv4 fallback
* automatic fallback to IPv4 if the reader have an AAAA and an A record and the connect via IPv6 failed
* automatic fallback to IPv4 name resolution if a user connects (with a set 'hostname' parameter) and have an AAAA and an A record and IPv6 does not match
* new reader option ipv4force = {0|1} (always use IPv4) to force IPv4 usage
Co-Authored-By: @w33dburner (hxxps://board.s​treamboard.tv/forum/thread/47800-ipv6-some-fixes/?postID=603397#post603397​)
* automatic fallback to IPv4 on server-listener
Co-Authored-By: @azurit3
build juli13
oscam-11812-mipsel.zip
(1.23 MiB) Downloaded 79 times
Return to “Oscam”
