All Ncam compiled and patched READ
Has thanked: 14363 times
Been thanked: 1660 times
Update ...
Ncam V14.6
- Fix some bugs with Streamrelay libdvbcsa compile
enigma2-plugin-softcams-ncam_V14.6-r0_all.ipk.deb
(4.69 MiB) Downloaded 162 times
eclair
Has thanked: 38 times
Been thanked: 10 times
Algeria
Re: Ncam V14.6 compiled and patched READ
Post by eclair »
Dommage ne marche pas avec mon VU+solo2 avec image OpenPLi 9.0 merci quand même pour votre partage
Ncam V14.7 compiled and patched READ
Ncam V14.7
Ncam-Images-IPK (For All devices that use ipk system)
NCam-Images-OSDreambox-DEB (For all Dreambox with DreamOS images that use dpkg system Such as (original image, Merlin4, Gp4, Dream-Elit ..etc))
fixed, some small things
Change (iCam-V9) to (StreamRelay) in the name of ncam version
Inform about using the wrong libdvbcsa library. in startlog and avoid crashes in this case
NCam-Images-OSDreambox-DEB.zip
(2.88 MiB) Downloaded 175 times
Ncam-Images-IPK.zip
(4.68 MiB) Downloaded 168 times
Ncam V14.8 compiled and patched READ
Update ...
Ncam V14.8
- Try to Support Sky UK
- Add emm unmask mode 4
(2.88 MiB) Downloaded 174 times
Ncam-Images-IPK.zip
(4.68 MiB) Downloaded 175 times
Ncam V14.9 compiled and patched READ
Update ...Ncam V14.9
- More Fix for Streamrelay
(2.88 MiB) Downloaded 88 times
Ncam-Images-IPK.zip
(4.68 MiB) Downloaded 115 times
kingsman
E2 Developer
E2 Developer
Has thanked: 13 times
Been thanked: 268 times
France
Re: All Ncam compiled and patched READ
Post by kingsman »
Ncam 15.0 compiled and patched READ
- omnicrypt: Add ecm support.
- Update reader-videoguard-common. this change has been in the forrums for a few years but not yet implemented thanks to (Didov3).
- revert to discarded parts, as they are also an important part of the module-serial.
- fix openssl dependency.
- added Fransat V6 cards to hanlde ECM of UHD Channels thanks to Constance and rumas84.
- add Dreambox Reader detection
- Dgcrypt 0x4AB0 with EMM * adding EMM Support for DGCRYPT 0x4AB0 thanks to lnj * adding support for non-standard ISO 7816-3 protocol for pcsc module thanks to lnj
- add hide Provid-SA IRDID
- Fix 'can't find 0xf0 in emm...' on Fransat V7 card (Thanks to nitida and OptimumPower)
Ncam 15.0.zip
(47.58 MiB) Downloaded 126 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Return to “Other Cardsharing Emulators”
