Ad blocker detected: Our website is made possible by displaying online advertisements to our visitors. Please consider supporting us by disabling your ad blocker on our website.
Posts: 8309 Joined: 31 Mar 2022, 14:41
Has thanked: 14324 times
Been thanked: 1629 times
Post
by SatEmpire » 05 Mar 2024, 09:46
[E² Plugin] TS-E2iplayer
04/03/2024
-Cb01 update link
-Altadefinizione update link
-Matrix: Update version 6.3.4e
-Update version
-Αdd parser VEEV
-FajerShow: add category ramadan
-Add New Host: CoolCima
Thanks MOHAMED OS
To install run the following command in telnet
wget --no-check-certificate "https://gitlab.com/MOHAMED_OS/e2iplayer/-/raw/main/install-e2iplayer.sh?inline=false" -qO - | /bin/sh
Download file
https://www.mediafire.com/file/wpuyzbs6 ... r.rar/file
ocean777
E2 Developer
Posts: 422 Joined: 14 Mar 2024, 13:48
Has thanked: 239 times
Been thanked: 210 times
Post
by ocean777 » 14 Mar 2024, 14:08
11/03/2024
-Update Link CimaNow
-try to fix dailymotion.com search
-Update link Cima4u
-Fix vod.tvp.pl
-Matrix: update version 6.3.4g
-try to fix yt
-Add parser RUBYSTMCOM
Thanks MOHAMED OS
ocean777
E2 Developer
Post
by ocean777 » 20 Mar 2024, 20:00
Update 19/03/2024
-Update name TvFun
-Fix TvFun
-Try fix WeCima
-Update link Cima4u & WeCima
-Matrix: try fix Yallalive
-Matrix: up ver 6.3.6a
-Matrix: update sites.json
-Update version
-Faselhd: try fix link watch
-Add New Host: brstej
Thanks MOHAMED OS
ocean777
E2 Developer
Post
by ocean777 » 27 Mar 2024, 13:46
Update 23/03/2024
Update otakufr_com.py
try to fix hostvizjerpl thnx zadmario
Update parse rUNIVERSAL
try fix Cinemana
remove ask
Update script install
Update link utils
Add Script Install pycurl
Add pycurl file
Add parser asnwish.com thnx Panda555
Fix Cb01 and Altadefinizione thnx Panda555
try fix Cinemana
try fix Esheeq
Thanks MOHAMED OS
ocean777
E2 Developer
Post
by ocean777 » 20 Apr 2024, 12:29
Update 19/04/2024
Add PKG "python-request"
Matrix: try fix EgyBest
Update Link :
- hosttuktukcinema
- hostshahid4u
Matrix: Update veresion 6.4.0b
vSTream:
- DULOURD] - Best search results
- Alldebrid - Testing token validity
- Ergonomics
Minor handling fix
Add parser vidhidevip and jodwish
Thanks MOHAMED OS
e2iplayer.zip
(18.03 MiB) Downloaded 132 times
ocean777
E2 Developer
Post
by ocean777 » 25 Apr 2024, 13:09
24/04/2024
Update version
Update Cimalek
Matrix: up ver 6.4.0e
Update BahyFilm
Matrix: try fix BahyFilm
Update link Esheeq
Add watched color in config
Fix parser VOESX
Try to fix voe.sx
Remove non-existing hosts
vStream: Update voe.py
Matrix: update Aflaam
Thanks MOHAMED OS
e2iplayer.rar
(17.46 MiB) Downloaded 111 times
ocean777
E2 Developer
Post
by ocean777 » 02 May 2024, 23:45
02/05/2024
* _1seriestreaming - Complete update
* ianime - "Dramas" menu added
* buzzmonclick_com - ADSlinkMe link decoding
try to fix parser CHILLXTOP
try to fix kinomoc.com
Add parser speci4leagle.com, vectorx.top
Update ANDROID_USER_AGENT
Remove host fullmatchtvcom not work
Update parser GOVIDME
Matrix: Up Ver 6.4.0g
fix Anime4up
Update Hoste using cMegamax
fix ShahiidAnime
try fix EgyBest
fix link Brstej
Update Link Lodynet
Update domain:
- Cb01
- Altadefinizione
Add New Host: Telebox
Thanks MOHAMED OS
e2iplayer.zip
(17.66 MiB) Downloaded 154 times
24 Nov 2025, 10:46
25 Nov 2025, 13:25
30 Nov 2025, 12:22
06 Dec 2025, 16:01
20 Dec 2025, 22:30
