[Plugin] xtraEvent
Has thanked: 14325 times
Been thanked: 1629 times
[Plugin] xtraEvent
enigma2-plugin-extensions-xtraevent_6.2_all
kitte888 wrote
Here to test it
is now just the plugin itself
If you leave it on clock, the plugin will download after 10 seconds
Then you set the timer to 1:00 and a download will be made every hour
If you set the number to 50, it should be a day in advance
In the download you can see the number of posters etc. You can also delete the folders here
enigma2-plugin-extensions-xtraevent_6.2_all.ipk
(723.45 KiB) Downloaded 133 times
Re: [Plugin] xtraEvent
enigma2-plugin-extensions-xtraevent_6.4_all
enigma2-plugin-extensions-xtraevent_6.4_all.ipk
(723.92 KiB) Downloaded 122 times
