Guys, I'll try to describe you with a little guide for Raspberry and for enigma2 "emm auto update".
- download the tool to install the pi version on micro SD for your Raspberry from the link https://www.raspberrypi.com/software/ (I used the pi command line version).
- with putty and with filezilla or WINscp, you can access the folders of your Raspberry or your decoder, and send the commands to start scsniff, and the emm auto update script.
- I placed the scsniff auto update script and the mini script that starts both scsniff and the emm script in the home folder.
- Start the script, command: . /startup .sh this starts scsniff and the emmsend script by opening a single putty window, either from the raspberry or from the enigma2 decoder, remember to give permissions to the 755 files, you can also do it with filezilla.
- It is important in the emmsend.sh script, your data must be entered:
http=192.168.1.110 #IP of oscam
port=16002 #oscam port
label=tivusat #Label tivusat
user= #only if it is available for the oscam wwbif
pass= #only if it is there for the oscam wwbif
Attached you will find the compiled versions for scsniff: enigma2, raspberry 2-3-4, the emmsend script, and the script that starts everything, interno.sh
Special thanks to the apprentice and luckysquid
Enjoy users
stay tuned
Raspberry PI 2-3-4-5 and enigma2 emm auto update.
- Has thanked: 14324 times
- Been thanked: 1612 times
- 983 Views
Last post by robertsdudlett
- 6722 Views
- 881 Views
- 4073 Views
- 27 Views
