[E² Plugin] Simple ZOOM Panel
- Has thanked: 14359 times
- Been thanked: 1667 times
Simple ZOOM Panel in PY3 ver.: 1.0
E2Wizard wrote
called Simple ZOOM Panel (it is like ZOOM but simple in PY3 . This plugin is designed to Download Servers and install ULTRACAM_OSCAM with config made for this servers (in the future there would be more features like iptv, plugins install, feed and many more!!).
It is build upon the fantastic work done by BextrH With BextrH’s gracious permission, I’ve taken the core ideas of their original plugin and expanded upon them to include support for PY3.
What’s New?
Key Features:
Feature 1: SERVERS (1) that will simply download servers for you.
Feature 2: ADDONS (1) Now it will only install OSCAM-ULTRACAM with optimized config for the servers .
Feature 3: EXTRAS (1) Now it can only uninstall plugin.
Getting Started: Only download this IPK and install it via USB Flash drive or FTP. (it will also install curl if it is not there)
This plugin was only tested on OCTAGON SF8008 AND VU+ ULTIMO 4K WITH OPENATV 7.3
What’s New?
Key Features:
E2W!zard added a new version:
Simple ZOOM Panel 2.0.0 "Phoenix"
Key Features:
User Interface:
A visually appealing MainMenu with intuitive navigation and detailed descriptions.
Easy selection and highlighting of options with arrow keys and action buttons.
Tools Section:
Access utility tools such as Free Cline Access with options to view the process or run scripts in the background with a self-update feature.
Extras Section:
Install and manage addons like AJPanel, SatVenusPanel, and media extensions like ArchivCZSK and ČSFD.
Manage dependencies like CURL, WGET, and CCCAMDATAX.
Settings Section:
Update the panel with the latest features and improvements. (note: This function will be done in future)
Help Section:
Detailed FAQs, contact information, and support options for troubleshooting and assistance.
Technical Details:
Import Libraries:
Utilized libraries for file handling, networking, threading, and GUI components.
Action Mapping:
Defined actions for key presses (OK, Cancel, Left, Right, Red, Green, Yellow, Blue).
Script Execution:
Improved script execution process with options for console output or background running.
Error handling and informative messages for seamless user experience.
Enhancements:
User Experience:
Enhanced selection display and detailed descriptions for each option.
Smooth navigation with real-time updates and feedback.
Reliability:
Robust error handling and confirmation prompts for critical actions.
Ensured script completion notifications and background process management.
Installation and Setup:
Simple installation from the IPK file.
Dependencies managed automatically during addon installations.
For a complete list of features and detailed instructions, please refer to the included documentation and FAQs within the plugin.
We hope you enjoy the enhanced functionalities and streamlined user experience with the latest release of the Simple ZOOM Panel Plugin. Your feedback and suggestions are highly appreciated and
Key Features:
User Interface:
Tools Section:
Extras Section:
Settings Section:
Help Section:
Technical Details:
Import Libraries:
Action Mapping:
Script Execution:
Enhancements:
User Experience:
Reliability:
- enigma2-plugin-extensions-simple-zoom-panel_2.0.0_all.ipk
- (165.12 KiB) Downloaded 199 times
Simple ZOOM Panel 2.0.1 " Phoenix "
HOTFIX:
1. Added additional Python 3 dependencies to the POSTINST script for light images (such as OpenPLi).
2. Removed the character "Č" in "ČSFD" is a UTF-8 character. Some images use ASCII encoding, which causes compatibility issues.
thanks E2W!zard
HOTFIX:
thanks E2W!zard
- enigma2-plugin-extensions-simple-zoom-panel_2.0.1_all.ipk
- (165.16 KiB) Downloaded 269 times
Simple ZOOM Panel 2.0.2 "Phoenix"
HOTFIX:
1. Removed all unicode characters
2. some fixes in FCA.sh
HOTFIX:
- enigma2-plugin-extensions-simple-zoom-panel_2.0.2_all.ipk
- (165.16 KiB) Downloaded 154 times
Simple ZOOM Panel 2.0.3 " Phoenix "
1. Added Python 3 libraries in the POSTINST script.
2. Added Python to dependencies to install Python 3 libraries.
thanks E2W!zard
thanks E2W!zard
- enigma2-plugin-extensions-simple-zoom-panel_2.0.3_all.ipk.zip
- (165.54 KiB) Downloaded 134 times
Simple ZOOM Panel 2.1.0 "Phoenix"
Online Update (Finnaly!)
FAQ section ordered
Installation now runs in the console for better information display
some code got cleaned up
FAQ section ordered
- enigma2-plugin-extensions-simple-zoom-panel_2.1.0_all.ipk
- (165.37 KiB) Downloaded 229 times
Re: [E² Plugin] Simple ZOOM Panel
Update 2.2.0
-Free servers added
-Plugin cosmetic changes
.ipk repacked by levi45 and added .deb file by levi45 (not tested)
-Free servers added
- enigma2-plugin-extensions-simple-zoom-panel_2.2.0_all.ipk
- (181.93 KiB) Downloaded 119 times
- enigma2-plugin-extensions-simple-zoom-panel_2.2.0_all.deb
- (176.89 KiB) Downloaded 118 times
thanks for this great work @ E2W!zard & HIUMAN
Update 2.2.0 new
-Free servers added
thanks Lululla py2 and py3
.ipk repacked by levi45 (for Permission 755 issue)
.deb file added by levi45 (tested working)
Update 2.2.0 new
-Free servers added
- (170.38 KiB) Downloaded 137 times
- (168.83 KiB) Downloaded 225 times
-Small fixes
After installation restart gui
edit lululla
put attached file in to folder
\usr\lib\enigma2\python\Plugins\Extensions\SimpleZOOMPanel\Centrum\Tools
edit lululla
- FCA.rar
- (3.53 KiB) Downloaded 102 times
This ipk/deb with latest modification and py2/py3
- enigma2-plugin-extensions-simple-zoom-panel-moded_2.2.1_all.ipk
- (172.14 KiB) Downloaded 198 times
- enigma2-plugin-extensions-simple-zoom-panel-moded_2.2.1_all.deb
- (170.14 KiB) Downloaded 160 times
- 1298 Views
- 321 Replies
- 57051 Views
Last post by liam
- 124 Replies
- 28144 Views
Last post by James
- 1578 Views
- 3441 Views
Last post by gregor1213
