[Plugin]E2m3u2bouquet
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
e2m3u2bouquet 1.0.61 (Mod Dorik1972)
1) Now, when a provider is deleted from the "card", all bouquets, config entries, and all channel picons of this provider are deleted (previously only config entries were deleted)
2) Minor code optimization
- enigma2-plugin-extensions-e2m3u2bouquet_1.0.61_all.deb.rar
- (1.18 MiB) Downloaded 242 times
- enigma2-plugin-extensions-e2m3u2bouquet_1.0.61_all.ipk.rar
- (1.33 MiB) Downloaded 275 times
- Has thanked: 14359 times
- Been thanked: 1668 times
Re: [Plugin]E2m3u2bouquet
UPDATE
1.0.65
Restored the functionality of customizing the generation of bouquets based on the override.xml template file
1.0.65
- kingsman
- Has thanked: 13 times
- Been thanked: 268 times
e2m3u2bouquet 1.0.94 Mod Dorik1972
1) Fixed an issue with handling unrealistically huge playlists with 500,000+ entries... Now, the size of the giant playlists processed by the plugin is limited only by the amount of free space on the storage device (HDD/USD/InternalFlash)
2) Refreshed IT locale
p.s. Changes in the code according to item 1) also apply to old receivers on sh4 architecture (mipsle) working on old images (like Pli4) in terms of processing any playlists ... but to expect high speed from MIPS architecture is a utopia
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.94_all.ipk
- (1.98 MiB) Downloaded 235 times
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.94_all.deb
- (1.98 MiB) Downloaded 270 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
e2m3u2bouquet 1.0.95 Mod Dorik1972
1) Fixed initialization of template file ***-sort-override (in its very first creation from scratch)
2) Fixed import of EPG events and picons for ***-sort-override users in 'All-in-one' mode for 'New broadcasts'
3) Reorganized bouquet refresh mode. Now the refresh occurs after the generation of bouquets for each of the providers, and not once for all as in previous versions
4) Added handling of HTTP errors 520, 526, etc. arising from providers working through CloudFlare
5) Completely eliminated the ability to start importing playlists until all previous tasks have been completed
6) Fixed crash on DreamOS-based images Merlin, Gemini, etc. due to the impossibility of saving settings when reloading (rebooting) the image
7) Small changes in the log output
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.95_all.ipk
- (1.98 MiB) Downloaded 234 times
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.95_all.deb
- (1.98 MiB) Downloaded 338 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
e2m3u2bouquet 1.0.96 Mod Dorik1972
1) Minor code fixes for Python2-based images when parsing Unicode characters in m3u playlists
2) Simplification and slight code optimization when forming and processing bouquets or sort&diff-override files
3) Redesigned installation scripts in ipk/deb packages
4) Added support for images based on Python 3.8 (OpenSPA 8.1, OpenATV 6.5, etc.)
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.96_all.ipk
- (2.06 MiB) Downloaded 249 times
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.96_all.deb
- (2.06 MiB) Downloaded 319 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
e2m3u2bouquet 1.0.96.1 Mod Dorik1972
1) Small additions to the Unicode character filter for m3u playlists parser
2) Fixed work with OpenVision images.
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.96.1_all.ipk
- (1.64 MiB) Downloaded 249 times
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.96.1_all.deb
- (1.64 MiB) Downloaded 254 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
e2m3u2bouquet 1.0.97 Mod Dorik1972
1) Fix for 'utf-8-bom' encoded m3u-playlists
2) Added parsing of 'streamlink://' entries for the streamwrapper plugin and 'http://localhost:port/' of the Streamlinksrv or Streamlinkproxy plugins in m3u playlists
3) ONLY FOR PYTHON3-based images!
Added support for full compatibility with Streamlinkproxy plugin and the ability to generate any bouquets for proxying broadcasts with this plugin. This option will appear in the "provider card" after installing the Streamlinkproxy Python3 Only! (C) Pepsik.
p.s. Attached is a test playlist for use with the Streamlinkproxy Python3 Only. Some broadcasts in it are geo-referenced and may not work in your region
- test_playlist.tar.gz
- (987 Bytes) Downloaded 611 times
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.97_all.ipk
- (1.65 MiB) Downloaded 262 times
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.97_all.deb
- (1.65 MiB) Downloaded 302 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
e2m3u2bouquet 1.0.97.1 Mod Dorik1972
1) Minor fix for a crash that occurred when trying to save the log to a file
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.97.1_all.ipk
- (1.65 MiB) Downloaded 260 times
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.97.1_all.deb
- (1.65 MiB) Downloaded 334 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
e2m3u2bouquet 1.0.98 Mod Dorik1972
1) Minor improvements in the algorithm for auto-selection of events from EPG by channel name (automatically used if you have specified a link to the EPG source in the provider's card). Now it works 10-15% faster than before
2) Changes have been made to the formation of comments for channel names and groups containing consecutive "-" characters in xml files. Now everything works without errors the same for xml.etree or lxml.etree ... There will be no more errors in the log if the name of the channel or group in the used playlist, for example, is "-----Music----" or "-----CINEMA------" etc.
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.98_all.ipk
- (1.65 MiB) Downloaded 281 times
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.98_all.deb
- (1.65 MiB) Downloaded 408 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- kingsman
e2m3u2bouquet 1.0.98.1 Mod Dorik1972
1) Fixed Python2-Python3 code compatibility when using the algorithm for auto-selecting events from EPG by channel name (Error: sequence must be integer not 'slice' )
2) Slight modification of regexp in the m3u-playlist parsing algorithm
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.98.1_all.ipk
- enigma2-plugin-extensions-E2m3u2bouquet_1.0.98.1_all.deb
- (1.65 MiB) Downloaded 277 times
VU+ duo4K
Multi R84
Multi R84 brutus z
Multi R84
Multi R84 brutus z
- 1319 Views
- 3472 Views
Last post by gregor1213
- 1033 Views
- 765 Views
- 606 Views
