[Plugin] HistoryZapSelector
- sugar
- Has thanked: 73 times
- Been thanked: 1669 times
History Zap Selector for OpenPli (6.x-9.x) © Dorik1972
A small and useful plugin for switching channels from the viewing history. Only FHD skin is included in the ipk file. The "Help" button calls for help in using this plugin. Plugin call - by short pressing the "blue" button on the remote control.
Puthon2/Python3 are supported
Thanks Dorik1972
Thanks Dorik1972
- enigma2-plugin-extensions-historyzap_1.0.4_all.ipk.rar
- (9.5 KiB) Downloaded 231 times
- Zaam
- Has thanked: 375 times
- Been thanked: 220 times
Re: [Plugin] HistoryZapSelector
UPDATE
1.0.23
1) Completely corrected for DreamOS-based Merlin image. Everything has been tested and works great
2) Fixed the logic for changing the number of entries in the channel switching list (set in the settings). Now everything works as it should
3) The plugin has been added to the main plugin menu of the image you are using
thanks Dorik1972
1.0.23
thanks Dorik1972
UPDATE 1.0.38
1) Added support for Python 3.12-based images
2) Small changes in the logic of processing standard SecondInfobar and EventView windows. Added support for custom Team_Nitro skins renderers
3) Updated Greek localization
- enigma2-plugin-extensions-historyzap_1.0.38_all.ipk
- (1.73 MiB) Downloaded 203 times
- enigma2-plugin-extensions-historyzap_1.0.38_all.deb
- (1.73 MiB) Downloaded 311 times
- ocean777
- Has thanked: 240 times
- Been thanked: 210 times
UPDATE 1.0.39
1) Added search for channels by occurrence of a given string in their title. Called by long pressing the yellow button on the remote control... Very convenient if you use VOD playlists to find the movie you want
- enigma2-plugin-extensions-historyzap_1.0.39_all.rar
- (1.74 MiB) Downloaded 121 times
- ocean777
UPDATE 1.0.40
1) Minor changes in the algorithm for searching for similar channel names or searching for the occurrence of a string in a channel name. Now works much faster, more accurately, and with less memory consumption
2) The base ConfigSelection class has been redesigned. If your image supports displaying graphics in the selection options of the settings window, then you will display icons instead of phrases. This modification also works on any DreamOS-based images. For example, this functionality can be “evaluated” on OpenPli, OpenBH, Merlin, GP4, etc. images.
- enigma2-plugin-extensions-historyzap_1.0.40_all.rar
- (1.74 MiB) Downloaded 95 times
- ocean777
UPDATE 1.0.41
1) Fixed a bug with the inability to select the key-file from the root directory
2) Minor code optimization
- enigma2-plugin-extensions-historyzap_1.0.41_all.rar
- (1.74 MiB) Downloaded 101 times
UPDATE 1.0.43
1) Fixed EPG translation language selection in plugin settings for GP4.2 image for DM ONE and TWO (possibly also for any other E2-images in which country flag icons are set in SVG format)
2) Added check for required rend
- enigma2-plugin-extensions-historyzap_1.0.43_all.ipk
- (1.79 MiB) Downloaded 107 times
- enigma2-plugin-extensions-historyzap_1.0.43_all.deb
- (1.79 MiB) Downloaded 245 times
- 1578 Views
- 1298 Views
- 3441 Views
Last post by gregor1213
- 1022 Views
- 751 Views
