[Skin]Aglare FHD
Been thanked: 1667 times
[Skin]Aglare FHD
Aglare FHD by MNASR
Aglare FHD v1.0
The supported images:
1- OpenATV 7.3 , OpenATV 7.4
2- Egami 10.4 , Egami 10.5
3- PureE2 7.3
4- OpenSPA 8.3
The skin depends on the new GUI features of oe-alliance .
There are 2 packages in dependencies :
oaweather plugin
bitrate plugin
Installation steps :
1- put IPK file in tmp folder
2- use this command in telnet
opkg install --force-overwrite /tmp/*.IPK
OR
using ajpanel and choose the IPK file and " install package (force overwrite) "
Thanks to Lululla for his great work to improve PosterX render
Thanks to madhouse for his great support.
https://www.mediafire.com/file/2w7i7ye6wjvj8h4/enigma2-plugin-skins-aglare-fhd_1.0_all.ipk/file
