It plays for a few seconds then stops!
Hi guys !
I correctly configured the software on PC, I updated it (v1.2.7.65 x64) but there are cuts at around 30-45 seconds even on VOD.
A friend did the same thing but it was at his house. Yet we use the same connection. I assure you that the connection is 100% operational so no worries about that.
Where could the problem come from?
Help me please !
THANKS
http://mol-2.com:8080
00:1A:79:00:00:09
- kerolorenzo
- New Member
- Has thanked: 14280 times
- Been thanked: 1572 times
Re: It plays for a few seconds then stops!
You need good Internet for this purpose
- kerolorenzo
- New Member
With the same connection, my friend got it very well. No internet problem
Try other linkskerolorenzo wrote: ↑29 Jan 2024, 23:32 With the same connection, my friend got it very well. No internet problem
- kerolorenzo
- New Member
same problem . If someone can try and tell me the results...
00:1A:79:00:00:09
00:1A:79:00:00:09
