AJPanel Plugin for Enigma 2
Been thanked: 1667 times
AJPanel Plugin for Enigma 2 Update..26/01/2024
- Added new window with split menus (DVB and IPTV Channels) to easily chain channels in:
- "Share Reference with DVB Channels (from xml file)"
- "Copy EPG/PIcons between Channels (from xml file)"
- Added new the option "Chain References to File Channels" in XML-TV page (to link DVB References to names in XML-TV files)
- Improved File Editor with Lines Multi-Selection (to copy/paste/delete).
Note: All edit-options have been moved from the Yellow Button to the Menu Button.
- Improved Custom Menu:
.. Added menu options to import other custom menus, delete menu items and change wallpaper/icons.
... Note: If the imported xml includes main icon (e.g. <ajp_menu icon="xx"...>), the icon will be set automatically.
.. Added menu options to change the wallpaper/shade/cursor picture and colors.
.. Added menu options to delete the cached picture files.
.. Added new xml attribute "picpath" to add a common path for icons and wallpaper. This way you can use file name witout path in all icons.
.. Added new xml attribute "box_gap" to Grid-Menu to increase the gap between boxes (vertically/horizontally).
.. Improved to play IPTV channels from a menu item.
.. External menu files can be added from any directory. If full path is not used, the backup directory is used.
.. Wallperaprs can be added List-Menus.
.. Menu wallperapr image (bg="") accepts Base65 fromat now.
.. Added Base64 pictures caching for faster loading.
.. Cached picture files will be saved into the cache directory "ajpanel_menu" (in the backup directory).
.. Deleting the cache directory will not harm. The panel will created it if necessary.
.. Fixed the crash on DreamTwo (Merlin) in the when aligning text.
- Improved Subtitle:
.. Increased Subtitle Min/Max delay time to 20 minutes.
.. Improved Subtitle settings value-picker.
- Fixed EPG option "Read Current Channel EPG" (epg is not imported after adjusting time).
- Fixed Search-by-Typing in Bouquet Editor
https://www.mediafire.com/file/bmdm8zgc ... k.zip/file
https://www.mediafire.com/file/7g7q09r5 ... b.zip/file
Re: AJPanel Plugin for Enigma 2
AJPanel Plugin for Enigma 2 Update..01/03/2024
- Ajpanel v9.3.0
- Improved "Backup SoftCAM Files" to include more softcam related files (e.g. PowerCam/SupCam/etc.).
- Added Subtitle menu option "Set Maximum Delay (Minutes)" to increase the maximum delay.
- Improved File Manager.
.. Added options to convert bootlogo mvi files to jpg/png.
.. Added options to convetr "tar.gz" to "tar.xz" (and vice versa).
.. Added options to convetr "tar.zst" to "tar.gz" and "tar.xz" (requires "zstd" package).
.. Improved the option "Unbuild Package" to handle ".tar.zst" files in the ipk/deb (requires "zstd" package).
- Added functionality to the option "Copy EPG between Channels (from xml file)" to chain DVB to DVB Channels.
.. The menu options will now open the last directories (for pictures and xml files separately).
.. You can change the Grid-Mode font size with the attribure font_size="x" (x is in range 10-50).
.. You can add "About" to show descritpion of your custom menu (or change-log) as follows:
... 1- Create a ".txt" file with the information you need to show.
... 2- Add a custom item with the name starting with the word "About".
... Example : <item name="About AJPanel">/media/hdd/xx/my_panel.txt</item>
- Improved Binder:
.. The option "Show Chains" (Green Button) will show more informative list.
.. Will show transponder data for the selected channel.
.. You can switch between TV and Radio modes (with RCU TV Button).
- Improved AJPanel Settings to create and use a default backup directory "../ajpanel_backup/" (if not set by user).
- Improved PIcons option "Suggest PIcons for Current Channel" to use case-insensitive search (for better result).
- Improved IPTV "Find" result to show the root category name in info. (with INFO button).
- Rearranged edit-options to use the Menu Button for more options (besides the Yellow Button).
- Fixed portal zapping in bouquets to point to the right name in Channel List (for duplicate Reference Codes in bouquet).
- Fixed the error "Cannot access the path" when accessing the Terminal from a Hotkey.
- enigma2 plugin extensions ajpanel v9.3.0 all.
https://sbupload.com/46e9ff8c7dc9eca6
- enigma2 plugin extensions ajpanel v9.3.0 all.deb
https://sbupload.com/6f188f4289f00f08
Ajpanel_v9.3.1
- Improved INFO button in Context Menu ("Find") to show Bouquet-Name for IPTV channels.
- Improved the option "Suggest PIcons for Current Channel" to find partaial file names.
- Fixed the warning message that appears when opening AJPanel.
- Fixed the problems of saving the backup-directory on some images.
enigma2-plugin-extensions-ajpanel_v9.3.1_all.deb
(395.21 KiB) Downloaded 186 times
enigma2-plugin-extensions-ajpanel_v9.3.1_all.ipk
(474.72 KiB) Downloaded 386 times
