Auto Change Wallpaper v4.3 [Mod]
Been thanked: 1028 times
Requirements: 6.0+
Overview: Auto Change Wallpaper swiftly and automatically changes your mobile wallpaper according to your wish in seconds.
This wonderful app gives an enticing look to your phone with your favorite images sliding on your mobile screen.
This awesome app lets you set the time gap where the image changes with a fully automated timer!
With auto change wallpaper you can add unlimited images or the entire photo gallery!
Make your mobile screen alive with your beautiful pictures and images that you love.
Check out these amazing features of auto change wallpaper:
- Auto change wallpaper does not over consume the battery!
- Auto change lock screen wallpaper!
- Change to next wallpaper when home screen visible!
- Change to next wallpaper when home screen hidden!
- Double tap on home screen to change to next wallpaper!
- Search and download photos from Flickr to your device and add to the album "Auto Change Wallpaper"!
- Select random photo in album when change to next wallpaper!
- Has a simple user interface!
- Easy to select and use your favorite images!
- Select as many pictures as you want!
- This cool app is absolutely free!
What's new:
- Added option: Set a blurred background for wallpaper when the scale type is "Fit".
- Fix some bugs and optimize app performance.
Package Info:
● Supported Languages: af, am, ar, as, az, be, bg, bn, bs, ca, cs, da, de, el, en, en-AU, en-CA, en-GB, en-IN, en-XC, es, es-US, et, eu, fa, fi, fr, fr-CA, gl, gu, hi, hr, hu, hy, id, in, is, it, iw, ja, ka, kk, km, kn, ko, ky, lo, lt, lv, mk, ml, mn, mr, ms, my, nb, ne, nl, or, pa, pl, pt, pt-BR, pt-PT, ro, ru, si, sk, sl, sq, sr, sr-Latn, sv, sw, ta, te, th, tl, tr, tw, uk, ur, uz, vi, zh, zh-CN, zh-HK, zh-TW, zu;
● Supported CPU architecture: Armeabi-v7a, Arm64-v8a;
● Supported Screen DPI: Ldpi, Mdpi, Tvdpi, Hdpi, Xhdpi, Xxhdpi, Xxxhdpi.
Mod Info:
● Premium Feature Unlock.
● All Unnecessary Setting Item Remove Like:
- Rate app, Recommend this app, Donate, Privacy Policy, ID contact us & Recommend apps.
● Ads Removed / Disabled.
● Receivers, Services And Provider Removed / Disabled.
● Google Play Service Check Remove / Disable.
● Google Play Store Install Package Check Disable.
● In-App Billing Service Removed / Disabled.
● Duplicate Dpi Item Remove Like:
● Splits0 File Removed (Resources & AndroidManifest).
● Splits0 Releated Unnecessary Meta-Data Remove Like:
● Total Apk Size 9.66 Mb.
https://uploadrar.com/azbbtmxubye3
