E2 logomatik [E-A]
- piplan1966
- Sponsor
- Has thanked: 176 times
- Been thanked: 283 times
- Has thanked: 14281 times
- Been thanked: 1572 times
Re: E2 logomatik [E-A]
Hi;
You can download the new version of LogoMatik [EA], ie Logo replacement program for E2 devices from below.
Click the "Scan E2 STB" button you can retrieve all the logos of your device which you have connected according to the information you have made in the ftp settings, save them as images and MVI, and modify and send your device again.
If you see a name such as "backdrop (link bootlogo)" in the name of the logos you get from your device, that image is the same as the bootlogo image, and uses the same mvi as the bootlogo.mvi file. Already in the program that logo cannot be changed and will appear blurry. You can also see in the picture above.
If you change the logo of your device, you must convert it to MVI with "Convert To MVI" button before sending it with "FTP Upload" button, then you can send your device.
With Free Logo button, you can save the desired pictures by converting them to MVI file without connecting your device.
With the "MVI to Jpg" button on the top right, you can convert the selected MVI file to a picture and save it as picture.
I tested the program with Blackhole, VTI, OpenPli and OpenSpa images with my Vu-Uno device. I do not know how to get results from other brand E2 devices because images like Vti or OpenPli have logos in a folder called "vuplus-bootlogo". So I don't know what will happen to devices like Dreambox, GigaBlue.
The program is still in beta..
I used some 3rd party components in the program and I embed them. For this reason the size is a little big.
The program will run on Windows Vista and above.
- piplan1966
- Sponsor
image name???
- piplan1966
- Sponsor
workpiplan1966 wrote: ↑01 Jun 2022, 12:47openatv 6.4
- piplan1966
- Sponsor
in me best konsi heShahid Geo wrote: ↑01 Jun 2022, 12:49work
OpenPli 8.2 best
- piplan1966
- Sponsor
brother openpli 8.2 download ki he lekin 4 file show hoti he image tab theek hoti he jab 6 file show hoti hn
no need 6 filespiplan1966 wrote: ↑01 Jun 2022, 14:30 brother openpli 8.2 download ki he lekin 4 file show hoti he image tab theek hoti he jab 6 file show hoti hn
you can install it
