IPTVnator is one of the best open source streams palyer , m3u player and more.... Cross-platform IPTV player application with multiple features, such as support of m3u and m3u8 playlists, favorites, TV guide, TV archive/catchup and more.
[HEADING=1][/HEADING]
[HEADING=1]All features[/HEADING]
-M3u and M3u8 playlists support
-Upload playlists from a file system
-Add remote playlists via URL
-Playlists auto-update feature
-Open playlist from the file system
-Search for channels
-EPG support (TV Guide) with detailed info
-TV archive/catchup/timeshift
-Group-based channels list
-Save channels as favorites
-Global favorites aggregated from all playlists
-HTML video player with hls.js support or Video.js based player
-Internalization, currently 7 languages are supported (en, ru, de, ko, es, zh, fr)
-Set custom "User Agent" header for a playlist
-Re-fetch/auto-update playlists
-Light and Dark theme
v0.14.0
What is new
The main feature of this release is — Xtream Code IPTV support. The feature is also available in PWA, but works best in electron version of the app and combination with mpv player.
Changes:
possibility to specify custom path for mpv player
fixed an annoying bug that appeared when reopening mpv player
fixed bug related to user-agent handling
updated libraries used under the hood
Download IPTVnator 0.14.0 Windows 64-bit
Download IPTVnator 0.14.0 Mac 64-bit
Download IPTVnator 0.14.0 Linux 64-bit
IPTVnator
- Has thanked: 14281 times
- Been thanked: 1572 times
IPTVnator
Users browsing this forum: No registered users and 27 guests
