Premium-FHD skin by MNASR
New skin
Premium-FHD v1.0
*The skin supports many images , in this initial version it will works with images based on oe-alliance , in the next version it will supports openpli based images , the difference is the new skin updates from oe-alliance team .
*The skin depends on old weather plugin , so it must be installed from the feed .
*The skin depends on PosterX render and Xtraevent plugin for showing posters .
*Tested on these images :
Openatv 7.3
Openatv 7.4
Openbh 5.3
Egami 10.4 R8
Openvix 6.4
*For openpli , wait for the next update .
[Skin] Premium-FHD
- Has thanked: 14324 times
- Been thanked: 1612 times
Re: [Skin] Premium-FHD
New Update
Premium v2.2
* add bitrate function to more images .
* fix some screens.
* add some screens " autocam and stream relay screens "
https://www.mediafire.com/file/ltloqrqn ... l.ipk/file
Premium v2.2
* fix some screens.
New update
Premium v2.7
* Fix oaweather plugin and Atilehd plugin to be compatible with python 3.12.1 , thanks [user='140973']madhouse[/user]
* Change virtual keyboard
* Removing some unused fonts and buttons
* Some other small fixes
* Still using PosterX render of Ozeta skin " thanks to [user='272076']Lululla[/user]
Size about 12.5 mb
Premium-FHD v2.7
https://www.mediafire.com/file/gxygfdjistrza82
Premium-FHD-Blue v2.7
https://www.mediafire.com/file/g0vafza9bhsdl6i
Premium-FHD-Black v2.7
https://www.mediafire.com/file/ek2gqlqhix3cc00
Premium v2.7
Size about 12.5 mb
Premium-FHD v2.7
- 1460 Views
- 6 Replies
- 9910 Views
Last post by Brigate01
- 78 Replies
- 32080 Views
- 109 Replies
- 75965 Views
Last post by VivaEuropeTV
- 595 Views
