install GP3 wizard and OneStep Cam Feed
1.Install gp3 wizard
2.restart Enigma2
3.go to plugins and install gp3
4.box restarts automatically
5.install Onestepcamfeed
6. restart the box
7. finished and you can install Cams from Blue Panel Addons
Note:—
Hi You Should Install Cams From BP Addons (press Blue Button then Addons)
They are all Correct
after install go to BP and CI-Softcam(Green One With Key Sign)
You Should See Your Cams Here
No Problem At all
And Please Don't install Plugins Or Emulators From Outside Of The BluePanel
BP Has All The Things You Need
Enjoy
How to Install Cams DreamOS Image
- 2902 Views
