Next INNOVA 4K Secret Codes/Firmwares
Has thanked: 14363 times
Been thanked: 1666 times
Next INNOVA 4K Secret Codes.
Master Password: / 0000
For Biss key 0000 Pacht on channel for menu, 6969
Stalker on channel, xtream iptv and server url to display 6969 Stalker in related menus 6363 Red button for Webtv ATV content 0000 For Cam/Server settings settings, menu+setup+ 6363
Boot logo menu+osd settings+
Continue….
Re: Next INNOVA 4K Secret Codes/Firmwares
Next Innova 4K V1.06.05 Software
(09.03.2023)
-Jet TV added.
-MyTuner has been added.
-Added application selection for IPTV button.
-Channel logos fixed.
- Various system improvements have been made.
*You can update the software on the device from the internet update section.
pamuk611
Been thanked: 6 times
Post by pamuk611 »
I'm new to these issues, I only use standard linux, enigma 2 and open atv are not installed on the device. I don't know how to install open atv and enigma, I want to update the oscam first, thank you very much for your help.
pamuk611
Post by pamuk611 »
Where can we find oscam update files?
Which type oscam support your box??
pamuk611
Post by pamuk611 »
oscam panel versiyon
Starttime: 13.07.2023 13:15:26
Version: oscam-1.20_svn-r11715-798
Compiler: arm-gcc49-linux-gnueabihf-ssl
Box type: generic (generic)
PID: 1479
TempDir: /tmp/.oscam
GBox tmp_dir: not defined using: /tmp/.oscam
ConfigDir: /home/gx/local/oscam/
pamuk611 wrote: ↑04 Aug 2023, 20:35 oscam panel versiyon
PID: 1479
Bro you have latest oscam install what problem you face??
pamuk611
Post by pamuk611 »
bro, at the end of long trials, I upgraded to 11720 oscam version, only in kodi application, twitch installation remained, i installed twitch, i just have a problem with login
thank you for everything
Where login problem oscam user pass??
User: root
Pass: root
pamuk611
Post by pamuk611 »
oscam problem solved, another problem left, thank you very much for everything
Return to “Others STB”
