AFN 9E autoroll Configuration 100% Work
Been thanked: 1668 times
AUroll work with this: Oscam-emu 11718 by MohamedOS
Oscam.conf
#### "*          ..:: A U T H O R ::..           *"
#### "*             << MOHAMED_OS >>             *"
#### "*           ..:: El Eulma ::..             *"
[global]
logfile                         = /tmp/oscam.log
nice                            = -1
waitforcards                    = 0
readerrestartseconds            = 1
preferlocalcards                = 0
lb_mode                         = 1
lb_save                         = 100
lb_nbest_readers                = 2
lb_nfb_readers                  = 4
lb_min_ecmcount                 = 3
lb_reopen_seconds               = 120
lb_reopen_invalid               = 0
lb_retrylimit                   = 200
lb_stat_cleanup                 = 24
lb_max_readers                  = 4
ecmfmt                          = P: c:p:s:d:i: #ECM_L:l #CW=w HOP:j
disablecrccws_only_for          = 1811:003311,003315;098D:000000;0500:030B00,042820;0604:000000;1819:00006D;0100:00006D;1810:000000;1884:000000;0E00:000000
cccam_cfg_reconnect_delay       = 90
cccam_cfg_reconnect_attempts    = 6
cccam_cfg_save                  = 1
[cache]
max_time                        = 15
[streamrelay]
stream_relay_enabled            = 1
stream_emm_enabled              = 5
stream_relay_ctab               = 098D,09CD
[dvbapi]
enabled                         = 1
au                              = 1
pmt_mode                        = 6
request_mode                    = 1
delayer                         = 60
ecminfo_type                    = 4
user                            = dvbapiau
read_sdt                        = 1
write_sdt_prov                  = 1
extended_cw_api                 = 1
boxtype                         = ENIGMA2 Boxes
[webif]
httposcamlabel                  = MOHAMED_OS
httpport                        = 8888
httprefresh                     = 10
httppollrefresh                 = 10
httphidetype                    = sh
httppiconsize                   = 30
httpshowmeminfo                 = 1
httpshowuserinfo                = 1
httpshowreaderinfo              = 1
httpshowcacheexinfo             = 1
httpshowecminfo                 = 1
httpshowloadinfo                = 1
httpallowed                     = 127.0.0.1,192.168.0.0-192.168.255.255,10.0.0.0-10.255.255.255,::1
 http_status_log                 = 1
Oscam.server
[reader]
label                         = emulator
protocol                      = emu
device                        = https://raw.githubusercontent.com/MOHAMED19OS/SoftCam_Emu/main/Enigma2/SoftCam.Key
caid                          = 0500,0604,090F,0E00,1010,1801,2600,2602,2610,4AE1
detect                        = cd
ident                         = 0500:000000,007400,007800,021110,023800;0604:000000;090F:000000;0E00:000000;1010:000000;1801:000000,001101,002111,007301;2600:000000;2602:000000;2610:000000;4AE1:000011,000014,0000FE
group                         = 5
emmcache                      = 2,1,2,1
 emu_auproviders               = 0604:010200;0E00:000000;1010:000000;2610:000000;4AE1:000011,000014,0000FE
Enjoy
lupe
Been thanked: 1 time
Aruba
Re: AFN 9E autoroll Configuration 100% Work
Post by lupe »
hi good morning whats the curent keys for this tx
lupe wrote: ↑14 Oct 2023, 18:06 hi good morning whats the curent keys for this tx
Latest keys here update
viewtopic.php?f=18&t=616&p=44836#p44836
Return to “Oscam”
