DevCheck Hardware and System Info v4.34 [Pro] [Mod Extra]
Requirements: 4.1+
Overview: DevCheck shows all the information you need to know about your device, hardware and operating system. The pro version features real-time system monitoring with completely adjustable translucent floating windows, plus theming options.
Dashboard: monitor CPU frequencies, temperatures, memory usage, battery stats, deep sleep and uptime
System: get all the info about your device name, brand, manufacturer, environment, Android version and kernel
Hardware: displays every known detail about your SOC, CPU, GPU, Memory and storage, including chip names and manufacturers
Battery: complete info on your battery status, temperature, level, technology, health, voltage, current and capacity (if available)
Network: shows info about your WiFi and mobile/cellular connections, including IP addresses (ipv4 and ipv6), connection info, operator, phone number, phone and network type
Sensors: a list of all sensors on the device, including type, manufacturer, power and resolution
PRO VERSION is available through in-app purchase
The pro version includes movable, always-on-top floating monitors. This allows you to monitor CPU frequencies, temperatures, GPU frequency, battery and system load in real time while using other apps. The size, transparency and position of the overlay windows is completely adjustable. On Android 5.0 and above, the floating monitors can be conveniently docked to the statusbar,
The pro version also allows you to switch between light and dark Material Design themes and choose from nine different color schemes (amber, blue, slate grey, aqua, red, green, orange, pink and indigo)
PERMISSIONS
This app requires many permissions in order to display all the detailed information in the app. None of this information leaves your device. This information is not shared in any way. Your privacy is respected.
NOTE: DevCheck version 4.34 and later now target SDK 31 and add new tools for Microphone, Bluetooth, Wi-Fi and GPS, which require additional permissions
4.34:
-bug fixes
Mod Info:
Pro / Paid features unlocked;
Disabled / Removed unwanted Permissions + Receivers + Providers + Services;
Optimized and zipaligned graphics and cleaned resources for fast load;
Google Play Store install package check disabled;
Debug code removed;
Remove default .source tags name of the corresponding java files;
Analytics / Crashlytics disabled;
AOSP compatible mode;
Languages: Full Multi Languages;
CPUs: armeabi-v7a, arm64-v8a, x86, x86_x64;
Screen DPIs: 160dpi, 240dpi, 320dpi, 480dpi, 640dpi;
Original package signature changed;
Release by Balatan.
http://ul.to/p9n2h3ql
