MultiStalker Pro Latest Version
- Has thanked: 14281 times
- Been thanked: 1572 times
Python 3
tv shows will be added soon after this release.
You can add your portals in MultiStalkerPro.json located in /etc/enigma2 but you can put the file in hdd and select it in the settings
Python 3
Re: MultiStalker Pro Latest Version
enigma2-plugin-extensions-multi-stalkerpro-py3_v1.0_all
Version 1.1 git39
-mipsel
-arm
-aarch64
-mipsel
-arm
-aarch64
- Been thanked: 2735 times
Version 1.1 git143
PY3.9 ARM Openpli develop only
openpli feed does not include python modules needed by the plugin, so before installing the plugin its necessary to install the python modules first then the plugin.
mipsel and aarch64 later.
- python3-rarfile_4.1-r0_armv7ahf-neon.ipk
- (31.49 KiB) Downloaded 269 times
- python3-levenshtein_0.12.0-r0_armv7ahf-neon.ipk
- (20.7 KiB) Downloaded 255 times
- python3-fuzzywuzzy_0.18.0-r0_armv7ahf-neon.ipk
- (9.03 KiB) Downloaded 257 times
- enigma2-plugin-extensions-multi-stalkerpro_1.1+git143+b0ff57a-r0_armv7ahf-neon.ipk
- (1.99 MiB) Downloaded 368 times
VIX/OBH
MIPSEL
MIPSEL
- python3-rarfile_4.1-r0_mips32el.ipk
- (58.48 KiB) Downloaded 135 times
- enigma2-plugin-extensions-multi-stalkerpro_1.2+git171+66a34f50+66a34f54b4-r0_all.ipk
- (2.89 MiB) Downloaded 264 times
ATV/EGAMI/PURE
MIPSEL
MIPSEL
- enigma2-plugin-extensions-multi-stalkerpro_1.2+git101+263845c0+263845c171-r0_all.ipk
- (2.6 MiB) Downloaded 328 times
OPENPLI DEVELOP
MIPSEL
MIPSEL
- (31.49 KiB) Downloaded 113 times
- python3-levenshtein_0.12.0-r0_mips32el.ipk
- (24.14 KiB) Downloaded 125 times
- python3-fuzzywuzzy_0.18.0-r0_mips32el.ipk
- (9.03 KiB) Downloaded 113 times
- enigma2-plugin-extensions-multi-stalkerpro_1.2+git169+1f4c695-r0_all.ipk
- (2.06 MiB) Downloaded 314 times
- ocean777
- Has thanked: 239 times
- Been thanked: 210 times
MultiStalkerPro 1.2
json UPDATE 23.06.24
- MultiStalkerPro.json.zip
- (723 Bytes) Downloaded 608 times
- ocean777
26/06/2024
- stb portal.rar
- (19.91 KiB) Downloaded 574 times
ipk for PLi based not dev..
Thanks lululla
enigma2-plugin-extensions-multi-stalkerpro_1.2+nss_all
https://fastupload.io/94055c401bc7a99e
Thanks lululla
- 3946 Views
- 5162 Views
- 88 Replies
- 8308 Views
- 406 Views
- 391 Views
Users browsing this forum: No registered users and 23 guests
