Play My IPTV v12.13.13.19 [Mod]
Overview: "Play My IPTV" is a video player capable of playing different types of online streaming lists. It can play m3u lists, Xtream/Ministra profiles, video/audio/image links and also local files.
Features:
- Create/Export/Import different types of profiles
- Fast playback of links and local files
- Visual themes
- Play last channel or video
- Parental control
- Choose video player
- Be able to play almost any type of video, audio or image
What's new:
- Add support to "stalker_portal" type portals.
- Press two times to go back in video player.
- Group m3u list by EXTGRP.
- Some minor changes and bug fixes.
Package Info:
● Supported Languages: af, am, ar, as, az, be, bg, bn, bs, ca, cs, da, de, el, en, en-AU, en-CA, en-GB, en-IN, en-XC, es, es-419, es-US, et, eu, fa, fi, fr, fr-CA, gl, gu, hi, hr, hu, hy, in, is, it, iw, ja, ka, kk, km, kn, ko, ky, lo, lt, lv, mk, ml, mn, mr, ms, my, nb, ne, nl, or, pa, pl, pt, pt-BR, pt-PT, ro, ru, si, sk, sl, sq, sr, sr-Latn, sv, sw, ta, te, th, tl, tr, uk, ur, uz, vi, zh, zh-CN, zh-HK, zh-MO, zh-TW, zu;
● Supported CPU architecture: Armeabi-v7a, Arm64-v8a, X86, X86_64;
● Supported Screen DPI: Ldpi, Mdpi, Tvdpi, Hdpi, Xhdpi, Xxhdpi, Xxxhdpi.
Graphic Optimizing Info:
● Optimized Png's: 100% | Saved: 131 Kb (22%);
● No Jpg's In Apk Detected;
● Storing Resources.arsc Uncompressed;
● Recompressing Classes.dex;
● Recompressing Libraries;
● Zipaligning Apk.
Mod Info:
● Ads Removed / Disabled.
● Receivers, Services And Provider Removed / Disabled.
● Google Play Services Check Removed / Disabled.
● Google Play Store Install Package Removed / Disabled.
● Duplicate Dpi Item Remove Like:
● Splits0 File Removed (Resources & AndroidManifest).
● Splits0 Releated Unnecessary Meta-Data Remove Like:
● Mod Apk Size 88.3 Mb.
https://uploadrar.com/k1is5ggk9c36
