A warning to anyone with this receiver & using recent firmware updates, if you go to the EBS channels on 9E the box will get stuck in reboot.
This happened to me, I tried to recover it by using a DUMP file posted on another forum, but couldn't get it to work.
Then I found out that you can use any Tiger One Million 4K firmware as long as you rename it: UPDATE.bin
I used the original V4.08 firmware on the USB & when it was loaded I updated to the latest firmware in the "SW Update" on the receiver, (Current version is V4.76).
Then I deleted the 2 EBS channels on 9E.
1. Put the firmware on the usb and rename it: UPDATE.bin
2. Turn the receiver off and then on again while usb is connected.
3. Press the OFF power button on the remote control continuously until you see the box updating on the front panel, - it should go from BOOT to USB & then start loading the firmware.
4. Once finished the box will reboot.
Dump file here
https://www.mediafire.com/file/4r1xxnwp ... P.zip/file
Tiger One Million 4K Recovery by USB
- Has thanked: 14324 times
- Been thanked: 1629 times
