IPTV playlist checker v1.0.20 [Mod]
Overview: Checking IPTV playlists for performance and relevance. Automatic bulk check of channels, online channel or offline. Editing channels of IPTV playlists in m3u format. Built-in IPTV player. It is possible to conveniently edit the channel list, change the name, video source. Organize your playlists. The ability to work with several playlists in different Internet sources. Multi playlists.
Supports XSPF playlists for smart iptv
The application does not contain embedded playlists, you will need to find playlists to work with the program.
Removed all trackers.
Languages: 'en' 'ru'
Architectures: armeabi-v7a
Improved app performance
Improved support for smart devices
Added support for groups
Sharing now you can share playlists with other apps
When saving, the last path is now remembered
Fixed minor bugs
https://uploadrar.com/f5r2av1xpy3d
