[Plugin] Wireguard VPN
kingsman
E2 Developer
E2 Developer
Has thanked: 13 times
Been thanked: 268 times
France
Post by kingsman »
Wireguard VPN V5.1
Wireguard Vpn for enigma2 boxes
Supported provider vpn for Surfshark - NordVpn - ProtonVpn
madhouse wrote
* Need the private key (Private Key) issued by your vpn provider (obtainable via the provider's website)
* Private key must be copied and pasted into the file located in /etc/Privatekey.key
* To import the key you have to run Wireguard Vpn, Green key (Configuration) Blue key - Load Private Key
Ps.
Wireguard Vpn plugin is not compatible with OpenVpn, if OpenVpn is running, you need to stop OpenVpn (if a boot setting is enabled, you need to disable it), you need to reset the Gateway (router ip) in the network configurations.
*Regarding NordVpn as of now you have to get your private key via a pc with linux os, by installing the NordLynx application, procedure attached (thx DIP80)
Unsupported decoders :
cube, spark, spark7162, dm900, dm920, vuduo2, vusolose, vusolo2, vuzero, vuuno, vuduo, vuultimo, vusolo, inihde2, jj7362, odinm9, et9x00, et6x00, et5x00, dags7356, dags7335, inihdx, inihde, inihdp, vg5000, vg2000, vg1000, ew7356, ew7358, ew7362, ixussone, ixusszero, blackbox7405, dm520, dm8000, dm7020hd, dm7020hdv2, dm800sev2, dm500hdv2, dm7080, dm820, yh7362, yh62tc, gb800solo, gb7325, ch62lc.
* Fixed network card restart
enigma2-plugin-extensions-wireguard-vpn_5.1_all.ipk
(1.09 MiB) Downloaded 341 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
Re: [Plugin] Wireguard VPN
Post by kingsman »
Wireguard VPN V5.2
enigma2-plugin-extensions-wireguard-vpn_5.2_all.ipk
(1.09 MiB) Downloaded 275 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
Post by kingsman »
Wireguard VPN V5.4
* Update internet library from urllib to requests.
* Added bypass file in /media/usb/
* Added the possibility in NordVpn to populate the list by country.
* Updated the translations it - de - pt - es.
enigma2-plugin-extensions-wireguard-vpn_5.4_all.ipk
(1.09 MiB) Downloaded 256 times
VU+ duo4K
Multi R84
Multi R84 brutus z
kingsman
E2 Developer
E2 Developer
France
Post by kingsman »
Wireguard VPN V5.5
* Fixed saving settings.
INFO
Save the configuration again using the green button
enigma2-plugin-extensions-wireguard-vpn_5.5_all.ipk
(1.09 MiB) Downloaded 295 times
VU+ duo4K
Multi R84
Multi R84 brutus z
ocean777
E2 Developer
E2 Developer
Has thanked: 239 times
Been thanked: 210 times
Andorra
Post by ocean777 »
Update V 9.5
* Fixed Status WireGuard.
* Fixed Status Handshake.
* Added compatibility for Zgemma h82h (Cortex-a7).
enigma2-plugin-extensions-wireguard-vpn_9.5_all.ipk.zip
(1.98 MiB) Downloaded 174 times
enigma2-plugin-extensions-wireguard-vpn_9.5_h82h_all.ipk.zip
(2 MiB) Downloaded 144 times
ocean777
E2 Developer
E2 Developer
Andorra
Post by ocean777 »
Update V 9.9
* Bypass logic fixed, it is now possible to add up to 400 host/ip.
* Fixed WireGuard tunnel running and stopping.
* Update .po files.
Thx @ Madhouse
enigma2-plugin-extensions-wireguard-vpn_9.9_all.ipk.zip
(2.02 MiB) Downloaded 162 times
ocean777
E2 Developer
E2 Developer
Andorra
Post by ocean777 »
Update V 10,2
Python 3.9: https://github.com/m4dhouse/Wireguard-V ... .2_all.ipk
Python 3.11: https://github.com/m4dhouse/Wireguard-V ... .2_all.ipk
Python 3.12: https://github.com/m4dhouse/Wireguard-V ... .2_all.ipk
ocean777
E2 Developer
E2 Developer
Andorra
Post by ocean777 »
Update V 10.3
Python 3.9: https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.11: https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Python 3.12: https://github.com/m4dhouse/Wireguard-V ... .3_all.ipk
Been thanked: 2741 times
Update WireGuard VPN V.10.7
* Fixed if hosts with the same IP address exist in the bypasses.
* WireGuard Vpn plugin built for mipsel and aarch64 architecture (only on Python 3.12).
* Updated the German translation (thanks @tommy007).
* Updated the French translation (thanks @gruick1).
* Updated the Greek translation (thanks giorbak ).
* Update .po and .pot files.
Python 3.12 (ARM)
Python 3.12 (AARCH64)
Python 3.12 (MIPSEL)
enigma2-plugin-extensions-wireguard-vpn-mips_10.7_all.ipk
(1.99 MiB) Downloaded 160 times
enigma2-plugin-extensions-wireguard-vpn-aarch64_10.7_all.ipk
(2.01 MiB) Downloaded 188 times
enigma2-plugin-extensions-wireguard-vpn_10.7_all.ipk
(2.26 MiB) Downloaded 191 times
Users browsing this forum: Bing [Bot] and 0 guests
