TM5402 M1/2/3 How to update to full 7 day epg
Been thanked: 1668 times
Make sure this transponder is in your list
11777 V 27500
if not add it in -
Installation- ADVANCED SEARCH -satellite 28e - Press green button to add tp- enter 11777 V 27500 - exit and save
Then
Do this in TV mode
Menu
Edit channels
Add channels
Select 11777 V 27500
Name channel EPG
Channel type TV
Video pid 3177
Audio pid 3176
Pcr pid 3177
Leave video and audio type as they are
Save
Exit
Reboot
Go to EOG channel
Press epg n remote and wait for update
Press yellow button to see other days update
Exit then press epg
Takes upto 2 mins to populate, if box is rebooted it will lose epg data and need to repeat process.
Return to “Others STB”
